    Sony DualShock 3 - call for testers: "sixaxis" script module
    sixaxisdriverbeta
    208 Posts 24 Posters 35.1k Views
    • H
      Headcrab @mitu
      While using the ps3 controller over bluetooth, i removed the sixaxis package and rebooted.
      The controller remained functional even after the reboot. (i'm confused by this)
      Then i reinstalled sixaxis from source, and the controller remains functional like before. The controller was already paired.
      To be clear, during all this process i used the ps3 controller over bt.
      Maybe i need to check on a fresh install, if the "thrid party support" additional package is installed by default?
      What should i be looking for?
        mitu Global Moderator @Headcrab
        @Headcrab said in Sony DualShock 3 - call for testers: "sixaxis" script module:
        Normally, 3rd party controller installs also the customhidsony driver package. So you can see in the list of packages from the drivers section if something new gets installed after installing sixaxis. Of course, the normal test to see if after the installation that the controller works without issues and you don't need to use the 'Disable 3rd party controller support', would be ideal.
        Thanks for testing.
        • H
          Headcrab
          I've done some more testing (i probably erased and burned the SD card about 10 times today)
          So i will do a recap.
          The problem
          When trying to pair an official ps3 controller for the first time, it is not being discovered.
          I get the message "No devices were found. Ensure device is on and try again"
          The steps
          • Burn the "retropie-buster-4.6-rpi2_rpi3.img" image on the sd card
          • boot into emulationstation
          • connect ps3 controller over usb and configure controls, so i can navigate
          • go to driver packages and install sixaxis
          • reboot
          • with the controller connected over usb navigate to Bluetooth > "Register and Connect to Bluetooth Device"
          • follow the instructions to unplug and re-plug the cable (and leave it connected)
          • it fails to discover the controller
          I confirmed that customhidsony is not installed after installing sixaxis.
          It does not show up in the driver menu. Also :
          ls -la /opt/retropie/supplementary/
          total 52
          drwxr-xr-x 13 root root 4096 May  1 12:51 .
          drwxr-xr-x  7 root root 4096 May  1 12:50 ..
          drwxr-xr-x  2 root root 4096 Apr 28 01:15 bashwelcometweak
          drwxr-xr-x  4 root root 4096 Apr 28 01:08 emulationstation
          drwxr-xr-x  2 root root 4096 Apr 28 01:09 mesa-drm
          drwxr-xr-x  2 root root 4096 Apr 28 01:12 omxiv
          drwxr-xr-x  2 root root 4096 Apr 28 01:08 retropiemenu
          drwxr-xr-x  3 root root 4096 Apr 28 01:09 runcommand
          drwxr-xr-x  2 root root 4096 Apr 28 01:05 sdl2
          drwxr-xr-x  2 root root 4096 May  1 12:51 sixaxis
          drwxr-xr-x  3 root root 4096 May  1 12:50 splashscreen
          drwxr-xr-x  2 root root 4096 Apr 28 01:14 usbromservice
          drwxr-xr-x  4 root root 4096 Apr 28 01:17 xpad
          If i hit the "disable third party support" option, i've found through the log that the following packages are installed:
          The following NEW packages will be installed:
            libbluetooth-dev libbluetooth3
          After a reboot i am able to pair my controller, but even then it is not solving the discovery problem every time.
          For example i had to switch to my other rpi3 board to make the controller discoverable in one of my tries.
            You don't need to reboot after the installation of the driver. Did you press the 'PS/Share' button before dis-connecting ?
            • H
              Headcrab @mitu
              I tried one more fresh install, just to make sure.
              I am pressing the PS/Share' button before dis-connecting.
              It is consistently not discovering the controller after installing the sixaxis driver.
              Doing the "disable thrid party" option and rebooting works 99% of the time.
                Thanks for testing - I'll add a note in the wiki for this.
                • H
                  Headcrab @mitu
                  Thanks for your time.
                  I hope we get confirmation from other ps3 controller owners at some point.
                  • wmarcioW
                    wmarcio
                    On my pi3b+ with retropie 4.6 on debian 9.11 wont worked, i made the same process...
                      mitu Global Moderator @wmarcio
                      @wmarcio said in Sony DualShock 3 - call for testers: "sixaxis" script module:
                      You're using a 3rd party controller, did you run the 'Enable 3rd party controllers' step ?
                      wmarcioW 1 Reply Last reply Reply Quote 0
                      • H
                        Headcrab
                        I've done some more testing, and found out that libbluetooth-dev does the trick.
                        So for the official ps3 controller these are the steps that work on my end.
                        • install sixaxis driver
                        • sudo apt-get install libbluetooth-dev
                        • reboot
                        • Connect the controller over usb
                        • Bluetooth menu > "Register and Connect to Bluetooth Device"
                        • Follow the on screen instructions
                          I think that's a red herring, the package contains only development files, without any impact on the Bluetooth stack that's running on the Pi.
                          EDIT: Hm, actually it seems to contain more than that. I'll take a look, but on my system this is not installed and the controller works ok.
                          • H
                            Headcrab @mitu
                            My findings are not based on actual knowledge of what each package does, so you are probably right.
                            But just to be clear, when you say that your controller works fine do you mean that when trying to Register for the first time, it is being discovered without that package being installed?
                              But just to be clear, when you say that your controller works fine do you mean that when trying to Register for the first time, it is being discovered without that package?
                              I never had that package installed and it's not installed now, so yes - discovery and (now) basic controller functionality worked without it. There might by a difference between systems though, I've paired and connected on a Pi4, which has a different BT chipset, so you being on a Pi3B+ might count.
                              • H
                                Headcrab @mitu
                                @mitu said in Sony DualShock 3 - call for testers: "sixaxis" script module:
                                I just "borrowed" a rpi4(1gb) from my nas setup so i can test this.
                                I performed these steps:
                                • Burn the "retropie-buster-4.6-rpi4.img" image on the sd card
                                The outcome was exactly like on my rpi3.
                                • Discovery fails.
                                • If i install libbluetooth-dev and reboot
                                • Discovery succeeds
                                Maybe it's a problem with my controller, i don't know.
                                Also, i do not own a ps3 console, so it is not interfering in any way.
                                • wmarcioW
                                  wmarcio @mitu
                                  @mitu, Hello, thank you, you are always helping people. My controller is original Sony, I always used the same controller, before upgrading to version 4.6, the same controller worked perfectly.
                                    @wmarcio What version did you run before the upgrade ? Did you install the 4.6 Buster image ? Did you enable support for 3rd party controllers ?
                                    • wmarcioW
                                      wmarcio @mitu
                                      I don't remember the previous version exactly, but I always update frequently, it was the last one before I upgraded to 4.6. Yes I did a clean installation for version 4.6 Buster, as I saw that it didn't work, I restored the previous image of raspbian 9.11 stretch and Retropie 4.6, that's when the problem started. Yes, I have enabled support for third party control.
                                        There's no difference between the previous (4.5.20) and the 4.6 version, except the version tag. There have been no modifications in quite a while for the bluetooth module in RetroPie, so I don't see what change in 4.6 might trigger this problem.
                                        Then I suggest you try the ps3controller package, it might work better with 3rd party controllers.
                                        • wmarcioW
                                          wmarcio @mitu
                                          @mitu ok, will try It. Thxs again.
                                            psyke83 Global Moderator @Headcrab
                                            @Headcrab
                                            Thanks for your troubleshooting efforts. It seems thatlibbluetooth-devitself doesn't fix your problem, but it triggers installation of the actual needed package - libbluetooth3, which contains the sixaxis plugin for BlueZ. This is quite odd, as I would have expected it to be present in a default Raspbian installation.
                                            I'll do some checking and report back soon.
