    Sony DualShock 3 - call for testers: "sixaxis" script module
    sixaxisdriverbeta
    208 Posts 24 Posters 42.7k Views
      @psyke83 Looks like - in my case - libbluetooth3 is also present, installed as a kodi dependency.
        psyke83 Global Moderator @mitu
        @mitu said in Sony DualShock 3 - call for testers: "sixaxis" script module:
        That also explains why I didn't notice the issue until now. This PR should fix the issue: https://github.com/RetroPie/RetroPie-Setup/pull/3125
          steeeb
          Thanks for the ongoing work on this.
          I can't seem to get my Shanwan controllers to pair. RPI3B+, Buster from download today, upgraded first (both the retropie_setup scripts and 'Yes' to the OS/Kernel when it asks if you want to update that as part of 'Update'.
          I've enabled third party support, which installs customhidsony.
          I go to Register and Connect to Bluetooth Device, and it takes around 15 seconds for anything to happen weirdly - it used to be instant - then I get the Searching.. screen (with third party support it has the DualShock string - without it, it doesn't). In any case, no devices found. I've even tried custombluez and that doesn't work.
          This used to work on an old Stretch build (I grabbed the original PR when sixaxis was first added as a pull request and it worked fine there).
          It looks like some error flashes up, I did it via SSH so I could see the error, it appears to be this:
          ^[[CTraceback (most recent call last):                                                  │ │
            File "/home/pi/RetroPie-Setup/scriptmodules/supplementary/bluetooth/bluez-test-device", line 44, in <module>              │ │        │ │
              adapter = bluezutils.find_adapter(options.dev_id)───────────────────────────────────┘ │
            File "/home/pi/RetroPie-Setup/scriptmodules/supplementary/bluetooth/bluezutils.py", line 14, in find_adapter              │                       <  OK  >            <Cancel>                       │
              return find_adapter_in_objects(get_managed_objects(), pattern)────────────────────────┘
            File "/home/pi/RetroPie-Setup/scriptmodules/supplementary/bluetooth/bluezutils.py", line 9, in get_managed_objects
              manager = dbus.Interface(bus.get_object("org.bluez", "/"),
            File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object
              follow_name_owner_changes=follow_name_owner_changes)
            File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 248, in __init__
              self._named_service = conn.activate_name_owner(bus_name)
            File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 180, in activate_name_owner
              self.start_service_by_name(bus_name)
            File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in start_service_by_name
              'su', (bus_name, flags)))
            File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
              message, timeout)
          dbus.exceptions.DBusException: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
          systemctl status dbus-org.bluez.service
          Looks to give:
          Active: inactive (dead)
          May 05 00:10:04 raspberrypi systemd[1]: Condition check resulted in Bluetooth service being skipped.
          The systemd line is added each time Register and Connect is pressed. It's inactive (dead) straight after I log in after boot.
          pi@raspberrypi:~ $ service hciuart status
          ● hciuart.service - Configure Bluetooth Modems connected by UART
             Loaded: loaded (/lib/systemd/system/hciuart.service; enabled; vendor preset: enabled)
             Active: failed (Result: exit-code) since Tue 2020-05-05 00:12:50 BST; 5min ago
            Process: 348 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
          May 05 00:12:20 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
          May 05 00:12:50 raspberrypi btuart[348]: Initialization timed out.
          May 05 00:12:50 raspberrypi btuart[348]: bcm43xx_init
          May 05 00:12:50 raspberrypi systemd[1]: hciuart.service: Control process exited, code=exited, status=1/FAILURE
          May 05 00:12:50 raspberrypi systemd[1]: hciuart.service: Failed with result 'exit-code'.
          May 05 00:12:50 raspberrypi systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
          pi@raspberrypi:~ $ sudo hciconfig -a
          pi@raspberrypi:~ $ sudo systemctl start bluetooth
          pi@raspberrypi:~ $ systemctl status bluetooth
          ● bluetooth.service - Bluetooth service
             Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
             Active: active (running) since Tue 2020-05-05 00:19:42 BST; 7s ago
               Docs: man:bluetoothd(8)
           Main PID: 1097 (bluetoothd)
             Status: "Running"
              Tasks: 1 (limit: 1772)
             Memory: 1.7M
             CGroup: /system.slice/bluetooth.service
                     └─1097 /usr/lib/bluetooth/bluetoothd
          May 05 00:19:42 raspberrypi systemd[1]: Starting Bluetooth service...
          May 05 00:19:42 raspberrypi bluetoothd[1097]: Bluetooth daemon 5.50
          May 05 00:19:42 raspberrypi systemd[1]: Started Bluetooth service.
          May 05 00:19:42 raspberrypi bluetoothd[1097]: Starting SDP server
          May 05 00:19:42 raspberrypi bluetoothd[1097]: Bluetooth management interface 1.14 initialized
          But it still won't pair - that's as far as I can get. Anyone have any ideas?
            steeeb @steeeb
            I've found the issue. Turning off wifi seems to break bluetooth! (It never used to, as I used to have it off beforehand too).
            Looks like theres a bug in the latest rpi firmware ^
            Only thing now is it seems L/R trigger is set to Axis 2+ and Axis 5+ and it takes like 10 minutes to be able to get EmulationStation to set it when setting up the controller (not checked if it works in game yet) - anyone else had this problem? Setting via USB has the same axis numbers but it's really easy to set.
              @steeeb
              The hid-sonydriver has two problems: it exposes both analog and digital events for the triggers, and in the case of the analog events, the triggers violate the Linux gamepad specification by having the resting position at -32767, when the specification calls for it to start at 0.
              Due to these issues, two workarounds are applied to EmulationStation for DualShock controllers during button setup - digital trigger events are ignored, and negative axis events are discarded (as most Linux software can't support analog button events that span both axes).
              The latter workaround means that it will only detect the triggers being pressed when at ~50% pressure or higher. I suspect you might be having this problem due to not pressing the buttons firmly enough. It's also possible that if you hold the trigger at <50% pressure (i.e. where it reports a negative axis value) for too long, EmulationStation thinks you are holding down a button with the intention to skip to the next button. I might take a look at the code again and see if that can be fixed, but can't make any promises.
              Finally, there's also a slight chance that your controller doesn't have a stable Bluetooth connection due to interference. My Pi model 3B has a revision of Bluetooth that doesn't support hardware flow control, which causes frequent ghost inputs - unless I manually lower the HCI baud rate. I'm not sure if any 3B+ models lack flow control, but it might be worth checking.
                steeeb @psyke83
                @psyke83 thanks - I got it recognised in the end and whilst playing the controller seems fine - it was just the initial set up. I think now I know the specifics, setting it up again would be easier I think it needs a quick press rather than a slow press from the sounds of it.
                Good work.
                • edge3000E
                  edge3000
                  Sixaxis has been working great for me on my Rpi4 running a new Retropie 4.6 install with all updates. Normally I can connect 7 dualshock 3's at a time without issue. But I found a way to break it partially.
                  @psyke83 I didn't see this mentioned in regards to Sixaxis:
                  If you disable ERTM (to get an Xbox One S controller to pair by bluetooth) or install Xpadneo (it disables ERTM during install) you will lose the ability to connect more than 4 Dualshock 3's at a time!
                  I tested this by disabling ERTM with this line in /etc/modprobe.d/bluetooth.conf
                  options bluetooth disable_ertm=Y
                  After reboot I can only connect 4 dualshock 3's.
                  Delete the file or set to disable_ertm=N
                  And after reboot I can connect 7 dualshock 3's again!
                  Just wanted to mention it in case anyone else runs into a similar problem.
                    MadHorse
                    @psyke83 Hi, I was away since a long time.
                    I'm installing the latest Retropie version on an Rpi 3 and wanted to try the sixaxis driver with a SHANWAN PS3 clone controllor.
                    I was able to pair the controller but not to connect, the led on number 1 turn on solid red for less than a second and then disconnects.
                    Sometimes happens that while doing it, Emulationstation crash.
                    This is the messages on bluetoothctl
                    Agent registered
                    [<span style="color:blue">CHG</span>] Device 00:26:5C:5D:BD:00 Connected: yes
                    [CHG] Device 00:26:5C:5D:BD:00 Name: PLAYSTATION(R)3 Controller
                    [CHG] Device 00:26:5C:5D:BD:00 Alias: PLAYSTATION(R)3 Controller
                    [CHG] Device 00:26:5C:5D:BD:00 Connected: no
                    [CHG] Controller B8:27:EB:75:21:27 Powered: no
                    [CHG] Controller B8:27:EB:75:21:27 Discovering: no
                    Agent unregistered
                    [DEL] Device 00:26:5C:5D:BD:00 PLAYSTATION(R)3 Controller
                    [DEL] Controller B8:27:EB:75:21:27 retropie [default]
                    Agent registered
                    [CHG] Controller B8:27:EB:75:21:27 Powered: yes
                    [CHG] Controller B8:27:EB:75:21:27 UUIDs: 00001801-0000-1000-8000-00805f9b34fb
                    [CHG] Controller B8:27:EB:75:21:27 UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
                    [CHG] Controller B8:27:EB:75:21:27 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                    [CHG] Controller B8:27:EB:75:21:27 UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
                    [CHG] Controller B8:27:EB:75:21:27 UUIDs: 00001800-0000-1000-8000-00805f9b34fb
                    [CHG] Controller B8:27:EB:75:21:27 Alias: BlueZ 5.50
                    [CHG] Controller B8:27:EB:75:21:27 Name: retropie
                    [CHG] Controller B8:27:EB:75:21:27 Alias: retropie
                    There is something I can try to solve the problem ?
                    Thank you in advance.
