    MSX not work
    4 Posts 2 Posters 3.2k Views
      backtomac
      Hello, I'm new to retropie,
      Here is my config :
      Pi3 B
      Retropie 3.7 setup by SD image
      Usb keyboard
      8bitdo sfc30 game padu
      Can't load any Rom & dsk in Bluemsx & fmsx . First time startup MSX dsk /rom in Bluemsx, it show up MSX startup animation screen, then get into the blue command line screen and nothing can do. After restart , load again it just quit to ES directly.
      Fmsx just get into blue command line screen.
      What can I do to get it work? Did I miss something?
      Thank you very much :)
        dunnster4u
        Hi
        have you put the MSX Bios in the "Bios folder" without this it wont work, heres a link that explains
        https://github.com/RetroPie/RetroPie-Setup/wiki/MSX
        Cheers
          backtomac @dunnster4u
          @dunnster4u
          yes I did , and I read the the wiki before start this topic :)
            dunnster4u
            Hi
            It can be sensitive to the correct BIOs, try getting hold of the BIOS from a different source and try that, most times that is the issue "wrong or bad Bios image"
            Cheers
