    xboxdrv - 2 zero delay encoders. Best way to determine p1 vs p2
    xboxdrv2 controllers
    13 Posts 4 Posters 2.1k Views
      mediamogul Global Moderator @psyke83
      @psyke83 said in xboxdrv - 2 zero delay encoders. Best way to determine p1 vs p2:
      You could write a udev rule to do what you want
      I really like that too. I experimented with using a udev rule for this at one time and although I didn't see it through, it looked like it would work well.
        psyke83 Global Moderator @mediamogul
        @mediamogul said in xboxdrv - 2 zero delay encoders. Best way to determine p1 vs p2:
        I really like that too. I experimented with using a udev rule for this at one time and although I didn't see it through, it looked like it was going to work.
        It will work if the rule is correctly implemented. I'm using precisely the same method for my sixaxis service: https://github.com/RetroPie/RetroPie-Setup/pull/2263
        One annoyance, as I said, is that hyphens get mangled during udev <-> systemd communication. I workaround that problem via a simple function in the script, however.
          @psyke83
          Very nice.
            spud11 @dsstrainer
            @dsstrainer I have 4 DragonRise usb zero delay joysticks and use the by-path method to mimic keys on a keyboard, accompanied by an appropriate udev rule. Like mediamogul, I've been using this set up for more than a year and haven't had any issues. I also use meleu's retropie-joystick-selection tool which is very handy too.
              dsstrainer
              Thanks for all the advice. Oddly though, my initial first test did not work.
              I decided to start small. Since I was only trying to get the player 2 encoder to have 2 buttons send out the 2 keys I have mapped to Save "]" and Load "6", I only used xboxdrv for those 2 buttons on that input.
              I mapped the 2 buttons on the encoder and started it with --detach. Then I was able to visually see that when I hit those buttons on the command line, it indeed typed out ] and 6
              I also have a keyboard plugged in and it also types out ] and 6
              But when I goto the game and hit those buttons, nothing happens. But if I use the keyboard, it works fine.
              I don't have the exact command line at the moment as I am not home but I'll paste that later. Still was surprised it didn't work.
              RetroPie v4.2 • RPi3 Model B • 5.1V 2.5A PSU • 8GB SanDisk class 10 microSD • 16GB External USB Thumb Drive
              Roms, images and configs stored in USB and symlinked from normal microsd location
              Xarcade Keyboard encoder + Zero Delay Joystick encoder
                dsstrainer
                ok here is the command line I used to test quickly:
                sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv --detach --daemon --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.3:1.0-event-joystick --evdev-keymap BTN_BASE=l2,BTN_BASE2=r2 --ui-buttonmap l2=KEY_RIGHTBRACE --silent
                So this is Joy number 2 (in the 1.3 usb port)
                I set the button which turns out to be BTN_BASE to L2
                Then I map the buttonmap of L2 to the "]" key which is KEY_RIGHTBRACE in xboxdrv
                On the command line, when I hit that button, I see it outputting the "]" key
                When I hit that key on my keyboard I also see the "]" key
                When I start a game and hit that mapped button, it doesn't nothing
                So where is the disconnect with it in the game?
                  My guess is that xboxdrv is creating a unique virtual uinput device node to emit the emulated keystrokes, but the emulator is only observing the actual keyboard's input event node? I have never used this daemon so I can't be sure.
                    dsstrainer
                    Well you are right.. I do see virtual devices. I will try without the daemon and see if that works
                      dsstrainer @psyke83
                      @psyke83 So how do you handle multiple joypads without running as a daemon? Just run multiple instances of xboxdrv process?
                        spud11 @dsstrainer
                        @dsstrainer That is correct.
