    No longer able to autoboot to ES after VPN/Transmission init script.
    autostartemultionstationvpntransmission
    9 Posts 2 Posters 1.3k Views
      gdallas
      Pi Model - Raspberry Pi 3 Model B Quad Core CPU 1.2 GHz 1 GB RAM
      Power Supply used: powered from NAS USB
      RetroPie Version Used - unsure how to check. sorry.
      Error messages received: none. just cant boot into ES.
      Guide used: https://www.htpcguides.com/remote-access-transmission-torrent-behind-vpn-linux/
      Hello. I can no longer use ES since following this guide, which I followed to allow remote Transmission Daemon access to my PI when using my VPN. This guide worked a treat, however my PI no longer boots into ES. instead the last row of text i see on my screen is
      'Initialization Sequence Completed'
      pressumably talking about by VPN setup.
      any ideas how i get it to carry on loading all ES etc?
      Many thanks
      G
        mitu Global Moderator @gdallas
        @gdallas What happens if you log in and start Emulationstation manually, by typing emulationstation at the command prompt.
        EDIT: You can try to use the RetroPie-Setup script and choose the autostart module to disable and then enable the autostart on boot, also choosing Emulationstation to be started on boot.
          gdallas
          @mitu said in No longer able to autoboot to ES after VPN/Transmission init script.:
          so from Putty I can SSH 'emulationstation' and it loads ok. but as soon as i close putty it goes back to the same screen with init seq completed etc.
          I have this code for my VPN that runs from /etc/rc.local. I tried adding emulationstation in there too but didnt load.
          sleep 10
          cd /etc/openvpn
          sudo openvpn --config /etc/openvpn/ipvanish-UK-Manchester-man-c06.ovpn --auth-user-pass /etc/openvpn/login.txt --script-security 2 --up /etc/openvpn/torrentvpn.sh --do$
          sleep 3
          emulationstation
          exit 0
            @gdallas You shouldn't load ES from the same script as the VPN. Use the RetroPie setup script as I mentioned and see if it auto-loads at start after you re-configure the boot/start options.
              gdallas
              ye I only just tried that there to check. was clutching at straws. Wasnt there when i posted. So i went into the RP setup script and done what you said. I got confirmation that ES would start at boot. but it didnt.
                @gdallas Modify the contents of /etc/rc.local and put an & (ampersand) at the end of the line with the openvpn command:
                sudo openvpn --config /etc/openvpn/whatever.ovpn --auth-user-pass /etc/openvpn/login.txt --script-security 2 --up /etc/openvpn/torrentvpn.sh --down /etc/openvpn/torrentvpnstop.sh
                should be
                openvpn --config /etc/openvpn/whatever.ovpn --auth-user-pass /etc/openvpn/login.txt --script-security 2 --up /etc/openvpn/torrentvpn.sh --down /etc/openvpn/torrentvpnstop.sh &
                You don't need sudo, since the script is already started as root.
                EDIT: replace the whatever.ovpn in the example command lines above with the actual filename you configured.
                  gdallas
                  Excellent, that seemed to work. Thanks mitu. I presume the issue was i just didnt copy the full code from that guide then?
                    @gdallas said in No longer able to autoboot to ES after VPN/Transmission init script.:
                    The original tutorial you linked didn't have the modification I mentioned, so the tutorial itself has the error. They should mention that the auto-start block added in /etc/rc.local blocks the boot sequence.
                      gdallas
                      Genius . Thank you very much. very happy now :-)
