    8BITDO SNES Controller Problems
    8bitdo snes
    2 Posts 2 Posters 490 Views
      Rdelaura
      So I just got these great controllers. I went into bluetooth settings and registered it then ran that config. It pairs and allows me to move around and select stuff in the bluetooth menu but as soon as I exit that config menu and go back into RetroPie main screen it doesnt work anymore. Still shows connected but no input is working. Please help
        mitu Global Moderator @Rdelaura
        @rdelaura Did you re-configure your input in Emulationstation after you paired them ?
