    Can I Scrape to my USB stick with Selphs scraper?
    scraper
    29 Posts 10 Posters 8.3k Views
    • FlightRiskF
      FlightRisk
      I thought that when I configured the selph scraper, it would put the graphics and videos with my roms. Instead, it filled up my boot sdcard. Now I have a lot of issues. So is there a way to change where it stores the images and videos, and if so, how do I move all the scraped stuff to the usb stick? (or delete it and start over) so I can free up space to operate.
      mituM ClydeC 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @FlightRisk
        @flightrisk Even if you move the scraped art to the ROM folder, you'd still have to correct the gamelist file and replace the paths, so it would be easier to remove the files and re-scrape again.
        The scrapers (selph's scraper and the build in one) both store the images in /home/pi/.emulationstation/, you should check that folder's size and clear up some room.
        • stooS
          stoo
          https://github.com/RetroPie/RetroPie-setup/wiki/scraper
          Enable "Use rom folder for gamelist & images"
          Scrape again.
          If you don't want to scrape again, move the images to an images subdir of your roms dirs, move the gamelist.xml to their respective rom dirs and do a search and replace on the gamelist.xml files to point to the new location.
            Clyde @FlightRisk
            @stoo said in Can I Scrape to my USB stick with Selphs scraper?:
            Those who don't shy away from a little Linux command line magic can use the tool "sed" for this:
            sed -i 's/.\/images/\/media\/usb0\/images/g' gamelist.xml
            This changes all occurances of ./images to /media/usb0/images in the file gamelist.xml. The pattern of the command is this:
            sed -i 's/old/new/g' filename
            That means that any occurance of the string "old" in the file "filename" shall be replaced by the string "new". Mind that any special characters like slashes / in both strings have to be prefixed by a backslash \ to mark them as a parts of the strings and not part of sed's syntax. Thus, ./images becomes .\/images and /media/usb0/images becomes \/media\/usb0\/images in the above example.
            As always, make a backup of your gamelist.xml before making any changes.
            • FlightRiskF
              FlightRisk
              Thanks for all the ideas. Gotta love anyone who has mastered sed, grep, etc. ;) The odd thing is that I DID set the scraper to "use rom folder". I assumed that would go to where I actually store my roms, which is an external USB stick plugged into the Pi 3. I did a "df" and don't see it listed, at least nothing that says USB. I use windows to copy the roms to the stick and then move it over to the Pi. Not sure if that has anything to do with anything or if it just isn't mounted. Retripie/ES finds all the roms.
              • herb_fargusH
                herb_fargus administrators @FlightRisk
                @flightrisk said in Can I Scrape to my USB stick with Selphs scraper?:
                It will if you have the USB mounted properly. If you just have it set to transfer it won't work that way.
                https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/
                • FlightRiskF
                  FlightRisk
                  I guess I need a refresher on Linux and mounting volumes, etc. When I first set this up, I ceated a folder on a windows pc called "retropie" onto the USB drive and stuck it in the Pi. It automatically copied my roms and a rom folder structure to the drive. When I do a "df", I thought I would see the USB drive, but I don't. I'm confused. It must be playing the games from it. Now I am looking at the "running roms from a USB drive" that you gave me and it says to enable a rom service and then create a folder called retropie-mount (not simply "retropie"). Do these steps do completely different things? I am afraid to add that folder without knowing what it will do, though I'll make a backup, of course, whatever I try.
                    Yes, the 1st will copy the ROMs from the usb to the sdcard (this is a ROM transfer method), the 2nd will auto-mount the USB and will run the ROMs from it.
                      Clyde @mitu
                      @mitu said in Can I Scrape to my USB stick with Selphs scraper?:
                      … after copying the RetroPie folder and all of its contents to the usb drive.
                      Just to be precise to avoid further confusion.
                      You should if it's mounted in the directory tree. By the way, df -h gives you a "human readable" (-h) output that lists the size in K/M/Gbytes instead of filesystem blocks. It's a quick way to check the filling level of all mounted file systems.
                      cyperghostC FlightRiskF 2 Replies Last reply Reply Quote 0
                        cyperghost @Clyde
                        @clyde @mitu
                        Even if it's not official supported ... Symbolic links will help out in this situation.
                        Old thread: can-my-usb-device-have-data-on-it-already
                        • FlightRiskF
                          FlightRisk @Clyde
                          @clyde @mito, would you recommend running everything off the USB? Seems like a win-win. Only con is something else sticking out of the Pi. Should be faster, more reliable, easy to move, backup, etc.
                          Also, will the second method (make a retropie-mount folder on the USB drive and have retropie automatically copy the retropie folder and leave the roms already on the stick) and then run everything off the USB keep what roms are on the USB? I will back up the USB first, but if I just add a retropie-mount with it in my PC, then move it to the Pie, will it do what it needs to do? Or would it erase the roms on the USB or even see that it is supposed to copy anything because it already saw the "retropie" folder and copied the roms and this is a one time thing?
                          Also, is the rom folder then still visible so that I can copy roms to and from the USB drive from my Windows PC instead of having to use a Samba link, SSH, etc.?
                          And last, the link @cyperghost gave mentioned issues if I move everything over because fat32 does not use linux permissons and I might have a lot of trouble configuring things to run scripts or whatever else I need for MAME and Dos games. I mostly care about the arcade games and less so with the consoles.
                            @flightrisk The usual reasons for running ROMs off the USB drive is reliability and portability. The USB is less likely to be corrupted than a SD card. Of course, if you're removing it, then you'll only see what you had previously copied on the SD card in the ROMs folder.
                            There is no '2nd method', the 1st method is for transferring ROMs via the USB drive onto the SD card, the only method to run off the USB card is this to use the retropie-mount folder on the USB driver and copy all the ROMs there. The 1st time after you insert the USB on the drive, the ROM folders will be created under the retropie-mount and you'll be able to copy ROMs to any of the sub-folders to make them appear on the RetroPie system.
                            As for the issue mentioned by @cyperghost, the problem is that symlinks are not supported by FAT32 partitions so you would not be able to symlink the artwork from the SD card folder to the ROM folder.
                            TL:DR - use the automated method mentioned in the docs (https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/) and you'll be fine.
                            • herb_fargusH
                              herb_fargus administrators @mitu
                              There are other issues with this method too: ie it doesn't always keep the same name so your symlinks may break, it's just not a very elegant solution.
                                cyperghost
                                @herb_fargus @mitu
                                Indeed the method is not very elegant but it's possible that this work without rescrape if the image folder will be copied to USB and a symlink that points from sdcard to USB is created. The other way a symlink file on a FAT32 does not work. So this is just a fast workaround.
                                But we want to avoid diversity in setup for maintaining reasons!
                                • stooS
                                  stoo
                                  The more I think about it, the more I don't understand why the gamelists and images aren't stored parallel to the roms by default. Same goes for all configs, now that I think about it.
                                  cyperghostC SanoS 2 Replies Last reply Reply Quote 0
                                    cyperghost @stoo
                                    @stoo Because you can use relatives pathes.
                                    But I see no advantage in this.
                                    /home/pi/RetroPie/roms/gb/Tetris.gb for a GameBoy game
                                    can result to a imagepath ./Tetris.jpg
                                    I would also like to see a database like SQLite
                                    That would make things much easier ;)
                                    So maybe every system got's it's own DB in a folder /home/pi/RetroPie/scraperdata/
                                    • SanoS
                                      Sano @stoo
                                      @stoo Regarding images and gamelists, I suppose it's the default for ease of use and cleanliness. Same types of files are in the same directory, so you could do batch processing more quickly and safely, you can easily only backup roms and not scrapped data, ... It also allows to have default similar configurations for all setups, which is better for dev and support. It's quite logical IMHO.
                                      Let's illustrate : You don't have a "Friends" folder containing pictures/videos of them, their VCF contact vcards and all your mail history with them, do you ? :)
                                      For configuration files, it's an all-time unix best practice to store them aside from data. Again for backup and security reasons, data management (different partitions for data), and because an unix/linux systems are multi-users. A config file is nearly always system wide, but data is by nature specific to a user.
                                      stooS 1 Reply Last reply Reply Quote 0
                                        Clyde @FlightRisk
                                        @FlightRisk As most of you questions were answered by the others, I'll just add some information.
                                        As far as I know, it doesn't erase anything, but just copies the files. It may overwrite any existing files in the same subdirectory and with the same name, but that should seldom be a problem and that's what backups are for, after all.
                                        The directory structure in the directory RetroPie will be recreated on the USB drive, and the drive stays formatted with VFAT, so you should be able to access your roms on it from Windows. However, the roms on the SD card won't be accessible at all as long as the USB drive is connected to the Pi, because the USB drive's directory structure will be mounted over the respective directories on the SD card. To access the latter over the network or from within the Retropie system, you'll have to start the Pi without the USB drive connected to it (there are other ways, but this is the easiest one).
                                        @cyperghost @mitu @herb_fargus Does the automatic method set the exec flag? Just curious, because the manual method only mentions it as an option in the docs.
                                        • stooS
                                          stoo @Sano
                                          @sano Yeah. It would just be nice if you could backup your home dir and know that all your scraped data and configs are covered.
                                          SanoS 1 Reply Last reply Reply Quote 0
                                          • SanoS
                                            Sano @stoo
                                            @stoo Actually if you backup your whole home dir (/home/pi) it should be the case, provided your backup method doesn't ignore hidden files and follows symlinks.
                                            You can also just add the /opt/retropie/configs/all/emulationstation path to your backup task.
