    IPEGA PG-9055 problem
    ipega pg-9055
    7 Posts 2 Posters 1.7k Views
      svayra
      Hi,
      I bought IPEGA PG-9055 game controller bluetooth.
      I have BT drivers and I have configured the controller in the BT options.
      Now retropie recognize it as keyboard.
      I tried as Android and as IOS but the rersult is the same.
      Someone can help me please?
      Thanks in advance
        mitu Global Moderator @svayra
        @svayra Check this topic for some instructions.
          svayra @mitu
          @mitu said in IPEGA PG-9055 problem:
          THANKS
          NOW ALL WORKS
          But there is a Bluetooth controller that work without a special configuration??
          Thanks again
            @svayra said in IPEGA PG-9055 problem:
            Yes, quite a lot of them actually. Your model is an outlier since it's primarily designed to work for Android.
              svayra @mitu
              @mitu can you link a model perfectly compatible please??
                @svayra Have you read the docs ? There's a whole section dedicated to Controllers, pick one that works for you. I've had no problems with 8bitdo controllers (SN30), Dualshock 4, Wii U Pro.
                  svayra @mitu
