    mapping buttons for xbox360 controller with reicast
    2 Posts 2 Posters 4.3k Views
      rossoe
      I wonder if someone could help me, I'm having a bit of a battle trying to get my xbox360 controller buttons sorted for Reicast. I can't for love nor money get my trigger buttons working?
      When I start up Marvel vs Capcom 2 - no response whatsoever from LB and RB buttons?
      I'm using 3.8
      evtest shows:
      Available devices:
      /dev/input/event0: USB OPTICAL MOUSE
      /dev/input/event1: USB USB Keyboard
      /dev/input/event2: USB USB Keyboard
      /dev/input/event7: Xbox Gamepad (userspace driver)
      /dev/input/event8: Xbox Gamepad (userspace driver) #2
      evtest /dev/input/event7
      Supported events:
      Event type 0 (EV_SYN)
      Event type 1 (EV_KEY)
      Event code 304 (BTN_SOUTH)
      Event code 305 (BTN_EAST)
      Event code 307 (BTN_NORTH)
      Event code 308 (BTN_WEST)
      Event code 310 (BTN_TL)
      Event code 311 (BTN_TR)
      Event code 312 (BTN_TL2)
      Event code 313 (BTN_TR2)
      Event code 314 (BTN_SELECT)
      Event code 315 (BTN_START)
      Event code 316 (BTN_MODE)
      Event code 317 (BTN_THUMBL)
      Event code 318 (BTN_THUMBR)
      My config file from - /opt/retropie/configs/dreamcast/mappings
      "controller_XboxGamepad(userspacedriver).cfg"
      looks like this:
      [emulator]
      mapping_name = Xbox Gamepad (userspace driver)
      btn_escape = 314
      [dreamcast]
      btn_a = 304
      btn_b = 305
      btn_c =
      btn_d =
      btn_x = 307
      btn_y = 308
      btn_z =
      btn_start = 315
      btn_dpad1_left =
      btn_dpad1_right =
      btn_dpad1_up =
      btn_dpad1_down =
      btn_dpad2_left =
      btn_dpad2_right =
      btn_dpad2_up =
      btn_dpad2_down =
      axis_x = 0
      axis_y = 1
      axis_trigger_left = 310
      axis_trigger_right = 311
      [compat]
      btn_trigger_left = 310
      btn_trigger_right = 311
      axis_dpad1_x = 16
      axis_dpad1_y = 17
      axis_dpad2_x =
      axis_dpad2_y =
      axis_x_inverted = no
      axis_y_inverted = no
      axis_trigger_left_inverted =
      axis_trigger_right_inverted =
      axis_dpad1_y_inverted = no
      axis_dpad1_x_inverted = no
      What am I doing wrong?
      I also tried to create mappings file using:
      /opt/retropie/emulators/reicast/bin
      ./reicast-joyconfig
      It only outputs a small list of settings - so the one above has been added to after searching blogs etc.
      Someone in this blog:
      https://www.reddit.com/r/RetroPie/comments/3ye3f0/cant_manage_to_configure_dreamcast_controls/
      "for LT and RT to work as an anolog trigger (just like it should) you must delete the xboxdrv parameter in /etc/init.d : --trigger-as-a-button and keep the other parameters"
      Is that part of my issue?
      • H
        Hyell
        Hello,
        for me (PI 3 with retropie 3.6) it's :
        axis_trigger_left = 2
        axis_trigger_right = 5
        and
        [compat]
        btn_trigger_left = 312
        btn_trigger_right = 313
        axis_dpad1_x = 16
        axis_dpad1_y = 17
        axis_dpad2_x =
        axis_dpad2_y =
        axis_trigger_left_inverted = no
        axis_trigger_right_inverted = no
        axis_dpad1_y_inverted = yes
        And you can use :
        btn_escape = 316 (Xbox button) to exit game.
        Have fun!
