    Flickering config problem?
    flickering blacscreen
    3 Posts 2 Posters 943 Views
    • L
      ljshooter
      Pi Model or other hardware: (B,)
      Power Supply used: (3.5 Amp micro usb)
      RetroPie Version Used (4.3 base image from RetroPie.org):
      Built From: (as above)
      USB Devices connected: standard keyboard
      Controller used: PS4
      Error messages received: none
      Log found in /dev/shm/runcommand.log (if relevant): no errors
      Guide used: (RetroPie.org first time setup)
      File: (N/A)
      Emulator(N/A)
      Hi I am after a little advice. I have set up my pi as above and trying to run it on my main tv but I am getting very intermittent flickering to a black screen (about every 30 seconds). To get to this point I had to set the config_hdmi_boost to 11 which I understand is not advisable to run of it can be avoided? I have been through the tvserice -m CEA to determine possible modes and have been through pretty much everyone now. The flickering gets worse as I ramp down the boost. Safe mode appears to work to a degree but appears almost out of focus. Guessing there is something else to try In the config file and I have done some searching but obviously it’s hard to narrow down with the varying hardware etc. Thank in advance
        To be honest, doesn't seem like a mis-configuration, more likely a bad cable.
        • L
          ljshooter @mitu
          @mitu and there you have it solved in 10 minutes flat. It was indeed a cheap hdmi causing the issue. Many thanks
