Number to call for help?
@hurkgt18 So this is your project? or what you hope to make? Your issue is that the zero has no power. If you are powering it from that amazon usb hub, there is your issue. The reviews of that device are not favourable and a lot of hubs just don't work with the pi. A quick search on here will show you. Also, you have just revealed what you might like to make but what is your current test setup exactly? more information is needed. Also, both micro usb ports can be used to provide "power" (ie. 5V) but only the "USB" labelled port has (USB) data connections.
@quicksilver said in Number to call for help?:
@hurkgt18 are your USB connections pushed all the way in?
Yeah they look to be half in on that setup!
@rbaker This is just a picture of someone elses project and how the wires plug into the Pi. If you look at the bottom of the picture, the first plug on the left is what the HDMI cord from the TV plugs in to. The next one over is what the power supply plugs in to. Then the three USB slots there are for controllers and thumb drives to add roms after Retropie is installed. This is how I have my cords plugged in to the pi. Obviously when I try to power it on I plug in the power supply to the correct cord.
@hurkgt18 You need to build the system step by step and the first step is to power the pi properly and get it working first. The recommended current capacity for a zero is 1.2A so your max of 500mA per usb on this hub is not a great way to power your pi and test it properly.
@rbaker Hey i wanted to thank you and everyone else who has commented for the help and support. I plugged the Pi in to my computer and it was recognized as a device so I know its not dead. I have a Canakit Pi Power supply arriving in the mail today too. I have retropie image written on a sandisk 16 GB and a sandisk 32gb micro sd card to help eliminate the chance of a bad sd card. Both those cards were listed as OK on the page of good and bad cards. Heres Hoping
UPDATE: I plugged my pi into my computer and my pc recognized it as a drive, so this means the Pi is not dead. I just received the Canakit Pi power supply, so my power supply is not the issue. I have to imagine it has to do with either the retropie image or the sd card itself. I swear I followed all instructions to the letter when writing the image to the pi but still the pi is not booting. I feel like i am taking crazy pills
@hurkgt18 said in Number to call for help?:
Describe what you are doing in order.
@rbaker he already has a thread open for this issue. No need to duplicate it here.
