    [HELP] GPIO signal during shutdown
    gpio shutoff
    2 Posts 1 Posters 362 Views
      cyperghost
      Hello fellows,
      According to the systemd helppage for system-halt we can initiate a script during shutoff sequence if we but a file to /lib/systemd/system-shutdown/ path. According to the halt signal we can choose between shutdowns, reboots .....
      I'm able to use the file with full GPIO support on a PI0/1 and a PI2 ... So the LED blinks 3 times during shutdown. I'm not able to run this on a PI3 with RetroPie 4.3 and the STRETCH images also. So there seems no initiation of a GPIO during shutdown here.
      So dear community I need your help. We need to connecte a LED to a working GPIO and to ground. then we need to create a small script and make it executable via chmod.
      1. type sudo nano /lib/systemd/system-shutdown/gpio-shutoff
      2. Insert code from box below!
      3. Make script executable with sudo chmod +x /lib/systemd/system-shutdown/gpio-shutoff
      4. Shutoff via commandline, ES menu or ....
      example shutoff script!
      #!/bin/sh
      # Testscript for proper GPIO signal on shutdown
      led_pin=17
          /bin/echo $led_pin > /sys/class/gpio/export
          /bin/echo out > /sys/class/gpio/gpio$led_pin/direction
              for iteration in 1 2 3; do
                  /bin/echo 0 > /sys/class/gpio/gpio$led_pin/value
                  /bin/sleep 0.2
                  /bin/echo 1 > /sys/class/gpio/gpio$led_pin/value
                  /bin/sleep 0.2
             done
      /bin/sleep 5
      So this script let's blink a LED connected to GPIO17 and GROUND
      If you test can you please tell...
      Which Raspberry did you use?
      Which version of RetroPie or annother OS did you use?
      Thank you
      cyperghost
      PS: @herb_fargus @BuZz any ideas? Link to starting thread
        cyperghost @cyperghost
        Tested: on Raspberry Pi 3 with RetroPie 4.3 and RetroPie 4.4 - works
        Tested: on Raspbian STRECH 4.9 kernel (March 2018) - works
        This is working flawless now!
