    Modify a safe shutdown script.
    shutdown scriptshutdownmenu
    20 Posts 5 Posters 5.7k Views
    • SixSpeedDeathS
      SixSpeedDeath
      When tinkering with a Super Kuma 9000 case, and shutting down, I noticed that occasionally the *.xml corrupts, so I peeked at the script, which kills the emulationstation process and then shuts the Pi down. Same with RetroFlag's new safe shutdown script.
      Can someone point me to the code emulation station runs when you select shut down from the menus, so I can try to incorporate that into the safe shutdown script, hopefully preventing xml corruption.
        mediamogul Global Moderator @SixSpeedDeath
        @sixspeeddeath
        I modified the ES kill portion of this script for my own needs and it's been working out very well for months now. An isolated safe shutdown based on my own would look something like:
        #!/bin/bash
        ESPID="$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")"
        if [ -n "$ESPID" ]; then
        kill "$ESPID"
        while s=$(ps -p "$ESPID" -o s=) && [ "$s" ] && [ "$s" != 'Z' ]; do
        sleep 1
        done
        fi
        sleep 1
        sudo shutdown -h now
        SixSpeedDeathS cyperghostC 2 Replies Last reply Reply Quote 1
        • SixSpeedDeathS
          SixSpeedDeath @mediamogul
          @mediamogul since I'm still a novice at this, will that allow emulationstation to finish writing whatever it needs to before shutting down?
            @sixspeeddeath
            It will indeed. I've been using it for months. One thing to note is that if you're going to be calling the script from a menu within Emulation Station itself, you'll want to call the script from another script. Meaning that if the script above was named killes.sh and it was located in your home folder, you would call it from another script accessible from an Emulation Station menu using something as simple as:
            #!/bin/bash
            bash /home/pi/killes.sh &
            SixSpeedDeathS 1 Reply Last reply Reply Quote 1
            • SixSpeedDeathS
              @mediamogul I was going to add it to the shutdown script located in "https://packagecloud.io/kintaro/pcb/packages/raspbian/jessie/kintarosnes_2.4.0_armhf.deb".
              It looks like the install runs it bases on GPIO inputs toggled by the switches.
              Are you saying I'd need to modify the script to toggle the menu item in emulationstation itself? Or that if emulationstation wanted to shutdown, it would need to access the new shutdown script?
                @sixspeeddeath
                Given your use case, you should only need the first script. I needed the combo, as I launch the script from the Kodi menu of Emulation Station, where I use it to shutdown ES safely and dual boot into OSMC.
                  cyperghost @mediamogul
                  @mediamogul said in Modify a safe shutdown script.:
                  @sixspeeddeath
                  I would add following line before the kill command
                  touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown
                  and then remove the sudo shutdown...
                  why?
                  Because ES startup scripts checks for presence of es-shutdown file and will initiate a shutdown itself.
                  If you use es-sysrestart it will reboot
                  use es-restart will restart ES
                  See this posting here
                  mediamogulM SixSpeedDeathS 2 Replies Last reply Reply Quote 2
                    mediamogul Global Moderator @cyperghost
                    @cyperghost
                    Very good to know. I'll add it to my own. Thanks.
                    • SixSpeedDeathS
                      SixSpeedDeath @cyperghost
                      @cyperghost I'll apologize in advance because I'm just starting to learn Linux, so I feel like a middle school kit at Harvard.
                      Does that disable the Reboot and shutdown menu's in Emulation station itself?
                      Is it possible to run es-shutdown from an external script, in essence shutting down emulation station in the same way that emulation station shuts down the pi?
                      My guess would be to replace the "sudo shutdown -h now" with "./path-to/es-shutdown"?
                      If I understand, and removing es-shutdown prevents someone from exiting emulationstation from the menu, that may come in handy for my arcade, but I wasn't planning on disabling it for now.
                      My goal is to dissect their script so I understand it better, and possibly modify it to shut down the RetroPie more safely.
                        cyperghost @SixSpeedDeath
                        @sixspeeddeath said in Modify a safe shutdown script.:
                        No ... it doesn't touch anything on the Graphic-Shutdown-menu
                        Yes you can run the script from a external script. You can also modify the script and can path parameters to it.... like ./es_action.sh shutdown to shutdown the Pie
                        or ./es_action reboot to Reboot the Pie or just ./es_action quites to terminate ES and go back to terminal.
                        No just erase that line. ES itself gots a little script that watches for action according to files placed in temp-folder. With touch you set a access date to a file. If the file is not available it will be created. It's better then to redirect like echo > /tmp/es_shutdown
                        If you start the script with /path/to/es_shutdown.sh the Pie will shutdown with sudo poweroffcommand hence to the explaination here
                        You can play arround with the script and learn some bash scripting. It isn't so difficult. Don't worry! And welcome to RetroPie
                        • SixSpeedDeathS
                          @cyperghost @mediamogul, I REALLY want to thank you for all your help.
                          I'm trying to change careers to Linux admin, and the RetroPie has been my "Carrot" for learning the OS.
                          Gradually, I'm picking the stuff up, but responses with information like what is supplied here do more than help me get a toy working, it's something I plan to use for the rest of my life.
                          I can only Bury my nose in a CompTIA book for so long before I need some hands on, and this is exactly what I needed.
                          Thank you.
                            @sixspeeddeath
                            Glad it worked out for you.
                            Drakaen391D 1 Reply Last reply Reply Quote 1
                            • Drakaen391D
                              Drakaen391
                              So, I love Python over Bash...
                              but I cant convert one over the other....
                              Any Ideas how to convert this to python?
                              RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
                              Retropie (Latest Stable)
                              PiBox with Wind Tunnel Cooling System
                              • Drakaen391D
                                Drakaen391 @mediamogul
                                @mediamogul I am using the original safe shutdown part...
                                import RPi.GPIO as GPIO
                                import os
                                import time
                                ###look at the GPIO for the Button Switch to be depressed
                                GPIO.setmode(GPIO.BCM)
                                GPIO.setup(3, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                                GPIO.wait_for_edge(3, GPIO.FALLING)
                                def main():
                                    while True:
                                        es-close()
                                def es-close():
                                    os.system("/etc/killes.sh")
                                while True:
                                    print((es-close))
                                    time.sleep(1)
                                    os.system("shutdown now")
                                and a very slightly modded es shutdown code
                                #!/bin/bash
                                #This Script was created by  #
                                #meleu on the retropieforums.#
                                # Check if EmulationStation is running. Finish the script if doesn't.
                                espid="$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")" || exit 0
                                # the "sed" command below isn't a crypted message :), it's just a trick to
                                # make $emucall regex-safe to use in the "pgrep -f" below.
                                emucall="$(sed '4!d; s/\([\\"]\|[[:alnum:]_]\+=[^ ]* \)//g; s/[][(){}^$*.|+? ]/\\&/g' /dev/shm/runcommand.info)"
                                # If there's an emulator running, we need to kill it and go back to ES
                                if [[ -n "$emucall" ]]; then
                                    emupid="$(pgrep -f "$emucall" | tr '\n' ' ')"
                                    pkill -P "$(echo $emupid | tr ' ' ',')"
                                    kill "$emupid"
                                    wait "$emupid"
                                    sleep 0.5
                                fi
                                kill "$espid"
                                wait "$espid"
                                sleep 0.5
                                • QuackwalksQ
                                  Quackwalks
                                  I'm not understanding how or where to fix the problem of the kintaro 9000 case not saving metadata.
                                  Pi Model or other hardware: Pi 3b
                                  Power Supply used: 5.1v 2.5a
                                  RetroPie Version Used: 4.3.17
                                  Built From: Pre made SD Image on RetroPie website, updated to 4.3.17
                                  USB Devices connected: dongle for wireless keyboard
                                  Controller used: Official PS3 Controller
                                  Drakaen391D 1 Reply Last reply Reply Quote 0
                                  • Drakaen391D
                                    Drakaen391 @Quackwalks
                                    @quackwalks Do you by chance have a large number of roms scraped?
                                    QuackwalksQ 1 Reply Last reply Reply Quote 0
                                    • QuackwalksQ
                                      Quackwalks @Drakaen391
                                      @drakaen391 I do have a large number of roms scraped.
                                      • Drakaen391D
                                        @quackwalks that could be the issue, increase the wait time a few seconds because emulationstation takes more time to save the meta data if there are alot of scrapped roms
                                          mediamogul Global Moderator @Drakaen391
                                          @drakaen391 said in Modify a safe shutdown script.:
                                          A static wait time really isn't a good idea for something like this. If you use something similar to the while statement in my example above, it will always take as as much time as it needs, no matter what the circumstances.
                                            cyperghost @Drakaen391
                                            @drakaen391 About your posted codings.... Does the wait command works in your case? @mediamogul and his while-loop by monitoring PID status is imho better ...
                                            wait can only be used on child processes out of the own subshell
