    All of thr sudden i cant switch to another emulator cause rom gets stuck with it forever help!
    emulation help
    10 Posts 3 Posters 900 Views
    • nestor1924N
      nestor1924
      I have no clue of whats going on this happens to all emumators now, if i choose one for a rom i cant change it back, i even delete the emulator i dont want but still shows up as the emulator choice and cant remove or change it back to another one, im still using the last version of retropie not the new one is that why?
        mitu Global Moderator @nestor1924
        @nestor1924 Use the Runcommand menu to switch emulators before running the ROM - as described in the Docs.
        nestor1924N 1 Reply Last reply Reply Quote 0
        • nestor1924N
          nestor1924 @mitu
          @mitu i know how to use the run command and its there when the issue happens, i cant switch or remove an emulator that i set up for a rom...
            @nestor1924 ok, so what does 'I can't switch' mean ? You don't get to the Runcommand launch menu or you the Runcommand menu does not work or ... ?
            • nestor1924N
              nestor1924 @mitu
              @mitu it works for example indownload a rom once open the command to choose what emulator i wanna use for it it lets say pifa and i wanna switch it to alpha it wont change at all, even if i out remove emulator from rom i wont remove it
                mediamogul Global Moderator @nestor1924
                @nestor1924
                Individual ROM preferences for emulators are set in /opt/retropie/configs/all/emulators.cfg. Can you confirm whether or not the individual settings are being removed from there?
                nestor1924N 2 Replies Last reply Reply Quote 0
                • nestor1924N
                  nestor1924 @mediamogul
                  @mediamogul how do i check that through win scp, im kind of new to commands and stuff...
                  • nestor1924N
                    @mediamogul this is what i got on that folder looking at it with notepad:
                      @nestor1924
                      Two things to note. First, long blocks of text should be posted to something like pastebin.com. Second, the listings you have there govern which ROMs are used by which emulators. For example, snes_BSF-ZeroGrandPrix2 = "lr-snes9x2005" means that the SNES system will launch the 'BSF-ZeroGrandPrix2' ROM using 'lr-snes9x2005' as the emulator. Try to remove one of those settings through the Runcommand window as you've been trying to and then revisit the emulators.cfg file to see if that entry has been removed.
                      • nestor1924N
                        nestor1924
                        sorry for that long post, just wanna notify that i was able to fix the problem, i deleted the ones that had the issue and now all of the sudden im able to change the emulator setting for the rom with 0 problems, weird... i guess ill say that the issue is solved?.
