    Controller configuration per system and finding device index number.
    10 Posts 3 Posters 3.8k Views
      matalog
      In /opt/retropie/configs/all/retroarch.cfg it says
      Device IDs are found in libretro.h.
      Does anyone know where libretro.h is located?
      Is there a way i could have searched for this file? I tried,
      find / -name libretro.h -print but it said permission was denied on all results and then, i tried this logged in as root and it showed no results.
      Thanks for any help,
      Matt.
        BuZz administrators
        https://raw.githubusercontent.com/libretro/RetroArch/master/libretro-common/include/libretro.h
          matalog @BuZz
          @BuZz Do you know where is is located on a retropie 3.8 device?
            BuZz administrators
            It isn't - it's part of the source.
              matalog @BuZz
              @BuZz # Sets which libretro device is used for a user.
              Devices are indentified with a number.
              This is normally saved by the menu.
              These settings are overridden by explicit command-line arguments which refer to input devices.
              None: 0
              Joypad (RetroPad): 1
              Mouse: 2
              Keyboard: 3
              Generic Lightgun: 4
              Joypad w/ Analog (RetroPad + Analog sticks): 5
              Multitap (SNES specific): 257
              Super Scope (SNES specific): 260
              Justifier (SNES specific): 516
              Justifiers (SNES specific): 772
              So then, where it says device IDs above - it's not talking about controllers on my system?
                BuZz administrators
                Please format your posts - see https://retropie.org.uk/forum/topic/3/read-this-first
                These are the ids used internally by retroarch afaik - perhaps it would just be easier to explain what you are trying to do ?
                  matalog @BuZz
                  @BuZz
                  '# Sets which libretro device is used for a user.
                  '# Devices are indentified with a number.'
                  '# This is normally saved by the menu.
                  '# Device IDs are found in libretro.h.
                  '# These settings are overridden by explicit command-line arguments which refer to input devices.
                  '# None: 0
                  '# Joypad (RetroPad): 1
                  '# Mouse: 2
                  '# Keyboard: 3
                  '# Generic Lightgun: 4
                  '# Joypad w/ Analog (RetroPad + Analog sticks): 5
                  '# Multitap (SNES specific): 257
                  '# Super Scope (SNES specific): 260
                  '# Justifier (SNES specific): 516
                  '# Justifiers (SNES specific): 772
                  '# input_libretro_device_p1 =
                  '# input_libretro_device_p2 =
                  '# input_libretro_device_p3 =
                  '# input_libretro_device_p4 =
                  '# input_libretro_device_p5 =
                  '# input_libretro_device_p6 =
                  '# input_libretro_device_p7 =
                  '# input_libretro_device_p8 =
                  I read that and assumed that I could order the player number of my controllers. It does look like that's what it is suggesting.
                  I became sidetracked when i was searching to see if there is anyway to have a controller specific configuration per system - do you know if there is?
                  Matt.
                  • herb_fargusH
                    herb_fargus administrators @matalog
                    @matalog in the documentation:
                    https://github.com/RetroPie/RetroPie-Setup/wiki/RetroArch-Configuration
                      matalog @herb_fargus
                      @herb_fargus
                      That doesn't seem to have all the information required - it doesn't mention how to find your selected joypads index - do you know how?
                        matalog @matalog
                        @matalog
                        What i am looking to do is have my wii u pro controller use different x,y,a,b button number assignments from my ps3 pads - because they are numbered differently on the devices - both on the NES.
