    Fan submitted themes built in
    themes
    9 Posts 3 Posters 726 Views
      shadow
      My idea: have a online page where you can peruse themes and choose to download them or not. People would upload there themes from there pc and they would show up on this page.
        mitu Global Moderator @shadow
        @shadow There is already a list of available themes page - https://retropie.org.uk/docs/Themes/ (which is editable) and you can choose to install one of the themes from the RetroPie-Setup menu.
        In order for the theme to be included by default in RetroPie, a PR should be submitted to the RetroPie-Setup github page and it will be included, but usually authors submit it first in the forums for beta-testing and feedback.
          shadow @mitu
          I know about the built in theme down loader, but I was suggesting to clean it up and have maybe a web page inside retropie itself.
            @shadow That's a neat idea, to have a preview option in the list before downloading a theme.
            • E
              EctoOne
              Isn't there a theme gallery in retropie? I believe I used it once, not sure though if it showed all themes.
                mitu Global Moderator @EctoOne
                @ectoone It's th themes page I mentioned - it seems somehow up to date, people gratiously edit the wiki page when new themes are added.
                • E
                  EctoOne @mitu
                  @mitu I was actually meaning that there is a gallery build in the retropie script though. I really think that I used it someday and it showed me some theme previews on my TV. I'm not at home, so I can't check it.
                    I checked and there is indeed a gallery preview option in the ES Themes package, it can be installed with the Download Theme Gallery , @EctoOne was right. Didn't use it before, but it looks quite handy.
                      shadow @mitu
                      @mitu I did not know that.
