    Roms and retropie settings dont start
    4 Posts 2 Posters 1.9k Views
      TheWolph
      Emulationstation starts fine but when I start a rom it goes to console then back to ES. ES will not even start raspberry -> audio settings or setup script ... ect it all does the same. I followed this tutorial the only thing I did wrong was I started a bin install then upgraded the script then I did another bin install. Also I'm starting ES from a script by cec-client.
      RetroPie-Setup ver 3.8.1
      uname -a Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
      Emulationstation 2.0.1a
      cat /etc/os-release
      PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"(from Raspbian lite)
      NAME="Raspbian GNU/Linux"
      VERSION_ID="8"
      VERSION="8 (jessie)"
      ID=raspbian
      ID_LIKE=debian
      other stuff = http://pastebin.com/fBV6ufd
      edit: I think my problem stems from not starting ES from the Display environment if that makes sense. After starting on ssh like this: sudo runuser -l pi -c /home/pi/GoogleDocs/Scripts/retrostart.sh i get:
      lvl0: from theme "/etc/emulationstation/themes/carbon/retropie/theme.xml"
      XML parsing error:
      Could not determine tag type
      ^[[C^[[C^[[C^[[C^[[C^[[C^[[C ^[[B^[[B^[[B^[[A sh: 1: cannot open /dev/tty: No such device or address
      ^[[B^[[B^[[B^[[B^[[B^[[B sh: 1: cannot open /dev/tty: No such device or address
      Starting using ssh to start emulationstation I get the launching game... on the client and a black screen on the pi
        BuZz administrators
        It needs to be started from a terminal - I suspect you are not doing that? eg if starting from Kodi you need to do some things like this (from retrosmc - https://github.com/mcobit/retrosmc/blob/master/scripts/retropie.sh#L35)
        What rom ? What are the contents of /tmp/runcommand.txt after launching ?
          TheWolph
          @BuZz
          there is no /tmp/runcommand.txt it doesn't get that far. Its weird because if start it manually /opt/retropie/supplementary/runcommand/runcommand.sh 0 PORT doom it works just fine but when i start it through ES I get "Unable to open /dev/tty"
            BuZz administrators
            That's because you didn't start Emulation Station from a terminal as mentioned in my previous post.
