    logoText help in theme
    themetheme helpsystem viewlogo
    36 Posts 5 Posters 9.1k Views
    • Stuart2773S
      Stuart2773 @paffley
      @paffley said in logoText help in theme:
      @stuart2773 said in logoText help in theme:
      @paffley
      i like both green & blue versions, you could make it optional or create 2 versions,
      have you looked on the "hyperspin" forums, theres a few files on there that may help you.
      Thanks @Stuart2773 I've had a brief look on there but could not see anything, have you seen something on there?
      if theres something in particular that you looking for, let me know, im pretty good at tracking things down lol
      • paffleyP
        paffley
        lol thanks @Stuart2773
        • Stuart2773S
          Stuart2773
          @paffley
          try this font:-
          https://mega.nz/#!QCR3wD6S!SAvLO4gx2n7ucOql_iPu7i9wyPVpfcpZySZvpZTnMTQ
          looks identical to this :-
          • E
            EctoOne @paffley
            I've got some great ideas to put my spin on it like....in place of the '000' at the beginning of a title, place the consoles relevant gamepad there in the same yellow/orange gradient.
            Since you want to use plain text as carousel, you can't have images.
            If you want to place the images separately or directly on the background image, they will probably be out of order because you can't detect what system someone is using. Like it was with the indicator images on chicuelo's theme. So it would only be viable for your personal setup. Or you have to create images with the controller and text and use those as carousel.
            Edit: The only other option is to have the controller image appear only for the selected system.
            paffleyP 1 Reply Last reply Reply Quote 0
              jdrassa @EctoOne
              @ectoone said in logoText help in theme:
              Edit: One last question for today: Why is image name="background" not available in system view? Seems weird to define an extra background image if I want to change it all views simultaneously.
              Not entirely sure, but I would guess that it was done this way to allow for system specific backgrounds and allow them to use animated transitions.
              Get latest build of EmulationStation for Windows here
                jdrassa @paffley
                @paffley the PR has been merged.
                • paffleyP
                  paffley @EctoOne
                  Hi @EctoOne , yeh I was meaning more for the basic/detailed/video view and not the system view.
                  • paffleyP
                    paffley @jdrassa
                    @jdrassa said in logoText help in theme:
                    @jdrassa Thanks! :)
                    • paffleyP
                      paffley
                      Thanks for the font @Stuart2773 I'll have a play...
                      • paffleyP
                        paffley
                        @jdrassa not for now but one for the future - how easy/hard would it be to add a stroke/outline to the text tag and possibly a gradient? I'm currently looking at how its done in attract mode.
                        • E
                          EctoOne @jdrassa
                          Hmm ok, to me I would make more sense if it was the other was around. Have one global background and every system gets an extra one. Especially since system specific backgrounds had to be set in system/theme.xml originally and not by using variables. But whatever, I was just courious and confused when my system background wasn't changing when I only had image="background" without extra="true=".
                          @paffley Ah I thought you wanted the controller images on system view as well.
                          • paffleyP
                            paffley
                            <text>${system.fullName}</text>
                            @jdrassa <text>${system.fullName}</text> works perfect on pi, thanks!
                              skj
                              @paffley
                              How is the progress going and Any idea when this theme will be released? Looks really amazing
                              • paffleyP
                                paffley @skj
                                @skj said in logoText help in theme:
                                @paffley
                                Thanks @skj …..I'm still working on it, got a few tweaks to make on it until i'm satisfied with it, I don't want to release something then make a thousand adjustments on it + it will only work with emu-dev installed at the moment until its been merged to the public ver. I'll create a separate post for it when its released as I work most days and doing this in my spare time. Keep popping back :)
                                • Stuart2773S
                                  Stuart2773
                                  any news updates on this theme?
                                  • paffleyP
                                    paffley @Stuart2773
                                    Hey @Stuart2773 not as yet mate sorry, still waiting for some of the features to make it to stable, not had much time lately to work more on it but I will eventually tho.
