    lr-mess and lr-mess2016 not compiling
    compile failedlr-messlr-mess2016
    30 Posts 11 Posters 5.3k Views
      jsevakis
      I just started with a fresh new build of RetroPie v4.4, and I'm loving how solid it is. However, I'm having some major show-stopper issues with trying to compile and install both versions of lr-mess. I'm literally just trying to install from the RetroPie-Setup script -- nothing weird.
      lr-mess install logs
      lr-mess2016 install logs
      I'm no expert when it comes to make and gcc+ but it looks like maybe something is amiss with one of the packages??
      Any help anyone can offer would be most appreciated.
      Device: Raspberry Pi 3B
      Overclock: none
      Power supply: Canakit
      Built From: RetroPie website image (v4.4)
      USB Devices connected: generic USB keyboard & mouse, Logitech dongle for wireless controller
      Controller used: SSH
      Error messages received: "Did not compile successfully. See logs for more info"
      Guide used: RetroPie wiki
        Yes, lr-mame2016 doesn't compile with a recent GCC (>5), there's even an issue opened on the github page with a similar error. For lr-mess, looks like insufficient memory (internal compiler error thrown).
        What are you trying to use them for ?
        J DougAD 2 Replies Last reply Reply Quote 0
          jsevakis @mitu
          @mitu I was trying to add CreatiVision, Emersion Arcadia and Dreamcast VMU support.
          If it's a memory error, then that would be my fault for trying to build something over SSH while forgetting to quit out of EmulationStation first. :D
          I'll try that. Thanks!!
          • DougAD
            DougA
            Raspberry pi 3b
            32GB Sandisk SD card
            64GB Sandisk usb drive
            Retropie 4.4.1 image from here
            Dragonrise zerodelay controller
            Canakit 5v 2.5A power supply
            Logitech K400 wireless keyboard/trackpad
            Is anyone else having issues compiling either lr-mess or lr-mess2016 from the experimental packages list? I tried both last night and in both cases I got a message
            Could not successfully build lr-mess2016 - MESS emulator - MESS Port for libretro (/home/pi/RetroPie-Setup/tmp/build/lr-mess2016/mess2016_libretro.so not found)
            or the equivalent for lr-mess
            Checking the log file for the compile, everything seemed to be compiling fine for lr-mess2106 until it got to
            Compiling 3rdparty/bgfx/src/bgfx.cpp...
            when I got pages of errors and then it gave up after about 25 minutes of total; compile time.
            lr-mess got much further (3 1/2 hrs) but threw up over an internal compiler error
            Compiling src/lib/formats/tzx_cas.cpp...
            g++: internal compiler error: Killed (program cc1plus)
            Please submit a full bug report,
            with preprocessed source if appropriate.
            • DougAD
              DougA @mitu
              @mitu By total coincidence, I posted almost the same issue just now, before seeing this thread. I also got the same errors when I tried to compile those two emulators last night. In my case I am attempting to emulate a BBC Micro. I hadn't quit emulationstation either, though I was working directly on the Pi
                mitu Global Moderator @DougA
                @douga @jsevakis I'm not sure if quitting ES would be enough, I remember a topic about a month ago about lr-mess compilation that - besides taking ages - doesn't succeed. You can try to quit ES, then run the compilation directly to see if it completes, but I'd leave it over night.
                EDIT: I've merged your other topic to this one.
                DougAD J 3 Replies Last reply Reply Quote 0
                • DougAD
                  DougA @mitu
                  @mitu well, it fell over at 3 1/2 hours running from inside Emulationstation, and it has run longer outside of it. I guess I will find out tomorrow morning.
                    jsevakis @mitu
                    @mitu Yeah, I just tried it without EmulationStation running and got the same error. There's probably not much else I can do to free up memory, is there?
                    In which case, this build script is simply not RPi compatible without some sort of fix for this RAM requirement. ☹️
                    DougAD 1 Reply Last reply Reply Quote 0
                    • DougAD
                      DougA @jsevakis
                      @jsevakis Me to. Exactly the same issue
                      • DougAD
                        DougA @mitu
                        @mitu @jsevakis I am going to try compiling it on a PC running RetroPie on top of Ubuntu over the weekend, just to see if I can reproduce the error there too
                          clewis
                          If anyone gets this figured out I would love to hear a solution. Cross compiling would probably be over my head.
                            BuZz administrators
                            Building in emulated chroot for example which is how I prepare binaries (with distcc cross compiler). I'll test increasing swap more - it was enough on Jessie. I'll have a look on Stretch.
                              clewis @BuZz
                              @buzz
                              Thanks! Hope it works out!
                              I can follow directions and looking to get lr-mame2016 running.
                                MadHorse
                                I have the same problem with lr-mame2016, did anyone find a solution for this error?
                                Thank you
                                • H
                                  hermit
                                  I have a similar problem with lr-mess: after about 12 hours it was "stuck" on the compilation of http.cpp
                                  raspberry 3b
                                  retropie 4.4 Stretch
                                  • DarksaviorD
                                    Darksavior @hermit
                                    @hermit It's still compiling. Press a key or button to see that you still get a response. To this day I can't get lr-mame and lr-mess to compile. I'm not trying again when lr-mess used to take over a day to compile on my pi3b only to fail. I have messed around with temp folders so ill remove that before trying again.
                                    I wish someone would provide a linux distro with cross compiling all set up. or a nice guide.
                                    • H
                                      hermit
                                      ok thanks
                                        I took a stab at compiling lr-mess (not lr-mame2016), both on the Pi and on a setup as the one described by @buzz (cross-compiling with distcc).
                                        Natively, on the Pi, the compilation crashed with not enough memory. I made the following modifications:
                                        • reduced the compilation concurrency so only 1 file is compiled at a time (-j1)
                                        • increased the swap added during compilation so you get a total of 2Gb or RAM (now the script ensures you have 1.4 Gb by adding a swap file).
                                        • reduced the number of drivers included in the core - only bbcb, arcadia and crvision were included.
                                        The compilation took more than 10h, but it finished and produced the mess_libretro.so core file (which is 45 Mb un-stripped, 27 Mb stripped).
                                        Cross-compiling from an Raspbian chroot via distcc is ... still compiling. Here, I reduced the make concurrency to 2 parallel compilations (-j2), but didn't exclude any of the drivers (so it should produce a full lr-mess core). The problem here is that distcc does not work 100% for cross-compiling because:
                                        • the build system in MAME adds the -x c++ argument to almost any driver compilation
                                        • distcc refuses to cross-compile this. As a consequence, there's no cross-compilation for any emulator included, so that's why I'm still waiting.
                                          It seems that distcc has a fix for refusing the compilation with -x c++, but the latest version available right now (in Debian) doesn't seem to include it. I might compile from source and re-try to see if there's any progress.
                                        I intend to re-run the native compilation on the Pi, maybe trying with -j2 to run 2 parallel compilations, and to include the full range of drivers in the core. Even adding a bigger swap file ( totaling 2G + or RAM), I still think the compilation might exceed 24h and be very slow on the Pi.
                                        Still waiting for the cross-compile to finish and re-try with a newer distcc.
                                        As a side note for cross-compilation, MAME seems to have support for it with a special target for Raspberry PI. The problem is that setting up a proper Raspbian ARM image to be used for cross-compilation is not trivial, although I think it can be automated.
                                        EDIT: cross-compilation finished, took almost 12h. Note that I haven't tested any of the resulting cores to see if it actually runs.
                                          circuitcreature
                                          I know this is an older post, but you do need to increase the swap space. I make a 4GB temporarily to get the compile to finish.
                                          Edit: It also takes forever in the PI, im about 24 hours in.
                                            OK, so I re-tried the compilation for both native and cross-compilation configuration
                                            1. Native - compiled with 2Gb or RAM (total) and 2 compiling processes (-j2). It finished in about 31 hours (stock 3B, no overclock, just heatsink).
                                            Building driver list...
                                            837 source file(s) found
                                            3043 driver(s) found
                                            Compiling generated/version.cpp...
                                            Compiling generated/mame/mess/drivlist.cpp...
                                            Linking mess_libretro.so...
                                            Removing additional swap
                                            real    1911m50.530s
                                            user    777m4.522s
                                            sys     79m13.794s
                                            As expected, the compilation is memory bound, with a few outliers that need > 1 Gb to compile and will effectively stop the compilation with heavy swapping - CPU is < 5% while the system just does swapping. For most of the compilation -j4 would be fine, but for these memory intensive files it will just increase the compilation times since the system will just try to accommodate 4 compilation processes.
                                            1. Cross-compiling - I updated distcc to get around the limitations noticed in my previous post, but it still refuses to compile most of the .cpp files (while compiling fine any .c sources). It might be a bug in distcc, but I'll need to check with a simpler setup if it's reproducible.
                                            All-in-all, I think for a RPI using -j2 and at least 2GB or RAM (right now it's set at 1400 Mb in the lr-mess.sh scriptmodule) would make the compilation finish.
