    Help me please no signal monitor VGA to hdmi
    help me pleaseno signalpi 3hdmi issuemonitor
    12 Posts 5 Posters 3.3k Views
      kid.icarus
      Hi, I've been making arcade table from an IKEA table. I finish the build yesterday and added retropie to the SD but I cannot get the monitor to acknowledge it is connected to the pi, all I get is a no signal message 😫
      I have a pi 3, the monitor has a VGA to HDMI cable connected. I am powering the monitor through mains and the pi has the correct per supply too. The monitor is an old Acer al1716. I have tried changing a few things in the config txt but I really feel out of my depths and so clueless because I've never done anything like this before.
      I know the pi works because I connected it to my TV and retropie worked. Please please please help me.
        mitu Global Moderator @kid.icarus
        @kid-icarus What exactly do you have in your config.txt file ? Did you look up to see what resolutions are supported by your monitor ?
        • Y
          youxia
          Connecting to an old monitor is not that straightforward. You should've done a bit of reading before jumping in.
          E.g: http://thegeekyway.com/connect-raspberry-pi-vga-monitortv/
          K 1 Reply Last reply Reply Quote 1
            kid.icarus
            @mitu # For more options and information see
            http://rpf.io/configtxt
            Some settings may impact device functionality. See link above for details
            uncomment if you get no picture on HDMI for a default "safe" mode
            #hdmi_safe=1
            uncomment this if your display has a black border of unused pixels visible
            and your display can output without overscan
            #disable_overscan=1
            uncomment the following to adjust overscan. Use positive numbers if console
            goes off screen, and negative if there is too much border
            #overscan_left=16
            #overscan_right=16
            #overscan_top=16
            #overscan_bottom=16
            uncomment to force a console size. By default it will be display's size minus
            overscan.
            #framebuffer_width=1280
            #framebuffer_height=1024
            uncomment if hdmi display is not detected and composite is being output
            hdmi_force_hotplug=1
            uncomment to force a specific HDMI mode (this will force VGA)
            hdmi_group=2
            hdmi_mode=38
            uncomment to force a HDMI mode rather than DVI. This can make audio work in
            DMT (computer monitor) modes
            hdmi_drive=2
            uncomment to increase signal to HDMI, if you have interference, blanking, or
            no display
            #config_hdmi_boost=4
            uncomment for composite PAL
            #sdtv_mode=2
            #arm_freq=800
            Uncomment some or all of these to enable the optional hardware interfaces
            #dtparam=i2c_arm=on
            #dtparam=i2s=on
            #dtparam=spi=on
            Uncomment this to enable the lirc-rpi module
            #dtoverlay=lirc-rpi
            Additional overlays and parameters are documented /boot/overlays/README
            Enable audio (loads snd_bcm2835)
            dtparam=audio=on
            gpu_mem_256=128
            gpu_mem_512=256
            gpu_mem_1024=256
            overscan_scale=1
            The monitor resolution is 1280 1024. I really think I've keyed everything as I should but still no luck
              kid.icarus @youxia
              @youxia I've done everthing the link suggested but still no luck
                @kid-icarus You should surround your config text with code marks (```), so it's easily readable. Some things to try:
                • hdmi_mode=38 means 1280x1024 @ 120Hz, but the specs of your monitor say 1280 x 1024 at 75 Hz, so try lowering the refresh rate and use something like 35 or 36.
                • hdmi_drive=2 makes no sense, since you're not going to be able to send sound over VGA.
                Look in the reference documentation (https://www.raspberrypi.org/documentation/configuration/config-txt/video.md) and choose the best options for your display.
                  kid.icarus @mitu
                  @mitu Thanks for your response. I have tried changing the HDMI mode but no joy. I have kept the HDMI drive set to two as I have external speakers mounted to the table and I read that 2 is for monitors and 1 is for tv's (I did also try setting the drive to one but no joy anyway) Thinking this is doomed to fail! From reading through that link you posted I cannot see what I am doing wrong. Would an older Pi be more suited to this style monitor?
                    @kid-icarus said in Help me please no signal monitor VGA to hdmi:
                    I doubt it, the video 'card' is the same in all PI models. I'd try mode video modes or a different HDMI/VGA (or maybe DVI) adapter if you can get one.
                      kid.icarus @mitu
                      @mitu Think I am going to try a VGA cable and a HDMI adapter rather than a straight VGA to HDMI... see if I have any luck with that. Its really strange that this monitor is not working with the Pi. I chose the monitor as Element 14 has a guide to make this "Pik3a" table and the same monitor was used and worked.
                      Y 1 Reply Last reply Reply Quote 0
                      • Y
                        youxia @kid.icarus
                        @kid-icarus Well, every guide I read on the subject says you need the adapter, not just the cable. So you should start with buying it if you don't have it already. Otherwise there's no point messing with config.txt and all that.
                          ChuckyP
                          Yes, I have seen a lot of problems with those cables. They are meant for projectors that have the correct logic to send a signal. They will not work with a passive VGA signal and convert to hdmi.
                          They make cheap converters (and nicer ones 😬) that will get the job done fine. But it will have to be an active process with some sort of dongle or box housing the electronics.
                          Also, VGA does not pass audio along either. So you may not have embedded audio on your HDMI feed.
                            edmaul69 @ChuckyP
                            @chuckyp most adapters have a headphone jack on them for audio which is far better quality than the jack on the pi.
