    Weird keyboard problem
    keyboard
    5 Posts 4 Posters 782 Views
      sixstring396
      Hey everyone. I have a problem with my wired keyboard. The letters work fine but the symbols are switched with each other. Pressing @ gives me " for example. Did I set up my keyboard wrong? I would appreciate any help.
        The default keyboard layout is the UK one, just reconfigure your keyboard with raspi-config and it should be fine.
          ChuckyP
          RetroPie uses the UK keyboard layout I believe. I used this advice I found on Reddit to change mine to US.
          From the command line enter sudo raspi-config. This will bring you into the Configuration Tool. Choose option 4 Localisation Options. Change to your preferred settings... EDIT: Choose Option 11 after choosing 4. Change Locale. Then pick en_US.UTF-8 UTF-8.
            sixstring396
            I tried this but its still not working. Any other suggestions?
            • caver01C
              caver01 @sixstring396
              @sixstring396 if I am remembering this right, you can install another locale, but you still need to SELECT it for it to take effect. Does that sound right? I seem to remember that one of the items in the long list has an asterisk by it which is the selected one being used.
              <EDIT> Yeah, here is a site describing what I mean. You hit spacebar to select the locale. That page has commands to bring up these screens, but this is all accessible through raspi-config
