    retropie with wireless mini keyboard
    wireless keyboatouch pad
    5 Posts 3 Posters 937 Views
      BrekDj
      Hello everyone. i bought a wireless mini keyboard to use with retropie, but it doesn't recognize the touchpad and the left and right click buttons. how do i solve this?
      thank you for support
      • DaistaarD
        Daistaar
        What EMU are you using that needs the mouse controls? Does the KB/M work on another device, say a PC? Does it work on a different build, say Raspbian on your Pi? You definitely need to provide some more info if you want any assistance.
          BrekDj
          i was configuring like a playstation, L and R are the commands for the mouse too. i tried on windows and everything works good. i have to use it with multiple emulators
            edmaul69 @BrekDj
            @brekdj for me l&r and the touchpad only work as mouse functions.
              BrekDj
              i discovered (trying) that autoconfiguration doesn't work for single emulators, like psx. so i read some internet guides.
              i configured it manually, editing the file /opt/retropie/configs/psx/retroarch.cfg
              adding this:
              input_player1_joypad_index = 0
              input_player1_b_btn = "k"
              input_player1_a_btn = "m"
              input_player1_y_btn = "i"
              input_player1_x_btn = "j"
              input_player1_l_btn = "n"
              input_player1_r_btn = "m"
              and this works. but i would like to use other buttons (the ones upper-right of this keyboard: https://www.google.com/search?num=20&newwindow=1&sa=G&hl=it&q=mini+wireless+keyboard+h9+2016&tbm=isch&tbs=simg:CAQSlwEJsBCE-pIGGwQaiwELEKjU2AQaBAgVCAAMCxCwjKcIGmIKYAgDEiixBoICpga6BrQGhxKgDLUGsAaGArwhqz2sPZ80wT23PbI94DaVNKI9GjBj7Kiy8UuBZo8x1oDaiZnH_1SIW4APyyJA5zG_1e3DOfb2yla_1PcHcPwD-Jzh0XPxiYgBAwLEI6u_1ggaCgoICAESBDolrPEM&ved=0ahUKEwjmoL-xr-LbAhWDiCwKHaiACOAQwg4IJSgA&biw=1360&bih=631#imgrc=kZkd0BQ1qYUw-M: )
              how can i do?
