    Kintaro Super Kuma 9000 Power switch problem
    kuma 9000 powerswitch
    4 Posts 4 Posters 2.3k Views
      sixstring396
      Hey everyone. I just gone done assembling my new super kuma 9000 and I am having some issues with the power slider. I have installed the script and that seems fine. However, I have to push it off and on several times before it will start or shutoff. Is anyone else having this issue or knows a fix?
        mitu Global Moderator @sixstring396
        @sixstring396 Move the power button in the off position, turn off the power (pull the plug), then plug it in again. It should shutdown, then power it on with the power button and from there on should work.
        If that doesn't work, then ask the seller about it, they provide good support.
          JoepKintaro
          Hi,
          Please try updating/upgrading the script;
          sudo apt upgrade kintarosnes
          Make sure to reboot afterwards :)
          Hope that works! If not, feel free to let me know.
          • L
            LinuxArcadeGuy
            https://github.com/KintaroCo/KintaroSnes
