    audio not working with 3.5 jack monitor 7"
    audio issues
    3 Posts 2 Posters 395 Views
    • L
      lollo1988
      i have build a arcade cabinet with monitor 7"
      https://www.waveshare.com/wiki/7inch_HDMI_LCD_(C)
      the retropie working weel with tv and audio to jack 3.5"
      when i plug the monitor 7" and setting this whit this configuration:
      max_usb_current=1
      hdmi_group=2
      hdmi_mode=87
      hdmi_cvt 1024 600 60 6 0 0 0
      hdmi_drive=1
      in config.txt the monitor working well
      but the audio in the game non working
      the audio in menu and in the game n64 working well
      i select in retropie menu 3.5 jack
      can you help with this problem thanks
      lorenzo
        Can you exit Emulationstation, then run from a command line
        sudo amixer cset numid=3 1
        # check the volume
        alsamixer
        Start ES again and start a game - see if it works.
        • L
          lollo1988
          don' t work i run your comand but the audio in the rom not working
          can i help me?
          i mod the the retroarch.conf for working audio?
