    8bitdo SNES30 Bluethooth Input Issues
    22 Posts 8 Posters 38.3k Views
      BuZz administrators
      if you update retropie-setup it has a new mode in the bluetooth setup to turn off the controller mapping hack that is needed for libretro emulators with the older firmware. You will need to remove / repair the gamepad first make sure the setting is off, and then reconfigure the controller in Emulation Station.
      Or just stay on the older firmware if it works for you.
      Y 1 Reply Last reply Reply Quote 0
      • Y
        yoink @BuZz
        @BuZz Just updated the firmware to stable 2.68 on the SNES30 controllers, disabled the hack, removed then repaired. Both are now working. Thanks.
