    Desmume loose framerate and the mouse pointer doesn't work
    ds emulatordesmumemouse pointerframerateaudio problems
    5 Posts 2 Posters 2.5k Views
      Tackskull
      Hi everyone,
      My pc is a laptop lenovo ideapad 320:
      processor: AMD A10-9620P
      Ram: 8Gb
      video card: AMD Radeon R7
      Hard disk: 1Tb
      Depending on the game I launch, many of them are easy to loose framerate and sometimes the games get back to his normal framerate. I don't understan on what it depends, if I play Castlevania order of ecclesia, sometimes the game became very slow with the audio starting to doing noises, and sometimes it just run well for a few minutes. I put the resolution on the minimum possible, but nothing to do.
      Another strange issue is that the mouse pointer for the touch screen doesn't work. I went on the option to enable the mouse, but nothign. If for example I want to set the Joypad's right stick to emulate the pointer, is woring ok. But Pointing the touchscren with a stick is so unconfortable so I would like to use my mouse, what can I do?
        Tackskull
        Anyone doesn't know how to fix the mouse for desmume emulator?
          mediamogul Global Moderator @Tackskull
          @tackskull
          After enabling the mouse, make sure you have 'pointer type' set to 'mouse'. Also, if you have multiple mice attached, be sure to select the right one from the mouse index listing in the player one input menu.
            Tackskull
            I don't have multiple mouses, but anyway where I can find this option of player one? If I start the emulator, then pressing select +Y I go on the retroarch configuration but cant find what you say
              @tackskull
              Move out to the root menu, then to 'Input'. From there, you should see the player one input map menu selection.
