    Could not successfully build lr-reicast - Dremcast emu - reicast port for libretro (/home/mac/RetroPie-Setup/tmp/build/lr-reicast/reicast_libretro.so not found).
    lr-reicast
    17 Posts 6 Posters 3.0k Views
      macsgv
      Hello, I have a problem when installing the lr-reicast emulator I get this error:
      Apparently can not find the file: reicast_libretro.so
      The rest of emulators work correctly :-)
      Any suggestions?
      RetroPie Setup v4.4.2 + Linux Mint 19 Tara + NetBook
      Greetings.!!!
      macsgv 3 minutes ago
      @buzz I keep getting the same error I leave the log if there is a solution
      RetroPie-Setup version: 4.4.2 (66a7d020)
      System: Linux mac-Aspire-one 4.15.0-23-generic #25-Ubuntu SMP Wed May 23 17:59:24 UTC 2018 i686 i686 i686 GNU/Linux
      ~/RetroPie-Setup/tmp/build/lr-reicast ~
      Getting sources for 'lr-reicast' : Dremcast emu - Reicast port for libretro
      git clone --recursive --depth 1 "https://github.com/libretro/reicast-emulator.git" "/home/mac/RetroPie-Setup/tmp/build/lr-reicast"
      Clonando en '/home/mac/RetroPie-Setup/tmp/build/lr-reicast'...
      Building 'lr-reicast' : Dremcast emu - Reicast port for libretro
      /usr/include/c++/7/new:122:7: note: in a call to allocation function ‘operator new []’ declared here
      void* operator new _GLIBCXX_THROW (std::bad_alloc)
      /tmp/ccGf7CVp.ltrans9.ltrans.o: En la función .L871': <artificial>:(.text+0x3e8d): referencia aGetRegPtr(unsigned int)' sin definir
      <artificial>:(.text+0x3eac): referencia a GetRegPtr(unsigned int)' sin definir <artificial>:(.text+0x3ecb): referencia aGetRegPtr(unsigned int)' sin definir
      <artificial>:(.text+0x3eea): referencia a GetRegPtr(unsigned int)' sin definir /tmp/ccGf7CVp.ltrans9.ltrans.o: En la función.L702':
      <artificial>:(.text+0x4f7d): referencia a GetRegPtr(unsigned int)' sin definir /tmp/ccGf7CVp.ltrans9.ltrans.o:<artificial>:(.text+0x5011): más referencias aGetRegPtr(unsigned int)' sin definir a continuación
      /tmp/ccGf7CVp.ltrans4.ltrans.o: En la función retro_unload_game': <artificial>:(.text+0x95ef): referencia angen_terminate()' sin definir
      /tmp/ccGf7CVp.ltrans8.ltrans.o: En la función ngen_CC_Param.constprop.19': <artificial>:(.text+0x97d1): referencia aGetRegPtr(unsigned int)' sin definir
      /tmp/ccGf7CVp.ltrans8.ltrans.o: En la función ngen_CC_Param.constprop.16': <artificial>:(.text+0x9a71): referencia aGetRegPtr(unsigned int)' sin definir
      /tmp/ccGf7CVp.ltrans8.ltrans.o: En la función ngen_CC_Param.constprop.14': <artificial>:(.text+0x9b72): referencia aGetRegPtr(unsigned int)' sin definir
      collect2: error: ld returned 1 exit status
      Makefile:605: recipe for target 'reicast_libretro.so' failed
      make: *** [reicast_libretro.so] Error 1
      Could not successfully build lr-reicast - Dremcast emu - Reicast port for libretro (/home/mac/RetroPie-Setup/tmp/build/lr-reicast/reicast_libretro.so not found).
        Can you update the Retropi-Setup script and then re-try the installation ?
          macsgv @mitu
          @mitu Hello mitu I am updating how it takes your time then I will tell you.
          Regards :-)
          • H
            hermit
            I can not find the emulator in the package list
            Retropie 4.4.2 + Raspberry PI 3 Model B
            • V
              vermope
              Did you manage to fix this issue? I have the same problem.
              I've updated the Retropi-Setup script and all other packages without any problems. I'm on X86 (elementary-os)
              *"Could not successfully build lr-reicast - Dremcast emu - reicast port for libretro
              (/home/peter/RetroPie-Setup/tmp/build/lr-reicast/reicast_libretro.so not found).
              Apparently can not find the file: reicast_libretro.so"*
                mitu Global Moderator @vermope
                @vermope What's the actual error you get during the compilation ? The lr-reicast works for me under Ubuntu x86_64.
                • V
                  vermope @mitu
                  @mitu these are the last lines of the log:
                  Makefile:734: recipe for target 'core/libretro/libretro.o' failed
                  make: *** [core/libretro/libretro.o] Error 1
                  make: *** Waiting for unfinished jobs....
                  ~/RetroPie-Setup
                  Could not successfully build lr-reicast - Dreamcast emu - Reicast port for libretro (/home/peter/RetroPie-Setup/tmp/build/lr-reicast/reicast_libretro.so not found).
                    @vermope said in Could not successfully build lr-reicast - Dremcast emu - reicast port for libretro (/home/mac/RetroPie-Setup/tmp/build/lr-reicast/reicast_libretro.so not found).:
                    These are not helpful to diagnose the issue, are just generic 'something failed to compile' messages. Get the full log file and upload it to pastebin.com. The setup script will create log files for each operation in $HOME/RetroPie-Setup/logs, find the latest one (they are timestamped) and put its contents on pastebin.com.
                    • V
                      vermope @mitu
                      @mitu Ok tnx! I look into it when I'm @home
                      • V
                        vermope
                        @mitu Here are the logs:
                        https://pastebin.com/RB0vfLbV
                          The error is
                          core/libretro/libretro.cpp: In function ‘void UpdateVibration(u32, u32, u32)’:
                          core/libretro/libretro.cpp:2328:123: error: no matching function for call to ‘min(__gnu_cxx::__enable_if<true, double>::__type, int)’
                              vib_stop_time[port] = get_time_ms() + min(1000 * (INC ? abs(INC) * max(POW_POS, POW_NEG) : 1) / FREQ, (int)max_duration);
                          In file included from /usr/include/c++/6/vector:60:0,
                                           from ./core/types.h:342,
                                           from core/libretro/libretro.cpp:4:
                          /usr/include/c++/6/bits/stl_algobase.h:195:5: note: candidate: template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)
                               min(const _Tp& __a, const _Tp& __b)
                          There's a compiler error that's not solvable by RetroPie - either update your gcc compiler or use more recent distro. What's the gcc version (g++ --version) ? I tested on Ubuntu 18.04 and 16.04 (+updates) and I don't get this error. Your OS seems to be based on Ubuntu 16.04.01 (while the latest patch version is for 15.04 LTS is 16.04.05), but using a very recent kernel (?), so I'm not sure which version is included.
                          • V
                            vermope
                            Woohoow, thank you @mitu !! I've upgraded the compiler and managed to install "lr-reicast".
                              saitoh00
                              This can be compiled under raspberry pi 3b+?
                                mitu Global Moderator @saitoh00
                                @saitoh00 No, it's available right now as an experimental package just for the PC.
                                  saitoh00
                                  ok mitu, very thanks, im hope al least we can test in Raspberry in the future, any plans to include it?
                                    @saitoh00 It depends on the development of the core, if it supports the Pi hardware.
                                    • N
                                      nipeters @mitu
                                      @mitu I'm hoping it does make it onto Raspberry pi 3b or 4!
