    Help Pcsx2 Retropie pc
    pcsx2
    5 Posts 2 Posters 997 Views
      gattinogerry
      Hi all I installed retropie on my pc with ubuntu 64 bit, but I can not add the emulator ps2, as it tells me that the program is only 32 bit, there is a solution? Thank you
        BuZz administrators @gattinogerry
        @gattinogerry Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
        What error ? It should work fine on 64bit (it will require removing our custom SDL libs through - it says this when installing)
          gattinogerry
          I'm sorry for the regulation I had not read.I can tell me that I have a 64-bit library, says that I must do a downgrade, but after that gives me error saying it only works on 32 bit
            gattinogerry
            Tomorrow I am attaching photos
              BuZz administrators
              I found an issue with pcsx2 install on Ubuntu 18.04. Rather than photos, just providing the information in the link would have been a better first step as it can help pinpoint the cause.
              You will need to update the retropie-setup script then run this command from a terminal though to resolve the issue (assuming your problem is the same as the issue I found with sdl2 not switching back to the packaged version correctly).
              sudo ~/RetroPie-Setup/retropie_packages.sh sdl2 revert
