X-Box One S Pad - Neverending Problems - Reicast Edition
Pi Model 3B+
Power Supply used: official
RetroPie Version 4.4
Built From: retropie-4.4-rpi2_rpi3.img
USB Devices connected: Logitech K400+, X-Box One S controller, Logitech Ergo (mouse)
Controller used: X-Box One S controller
Error messages received: NONE
Parameters:
Executing: bash "/home/pi/RetroPie/roms/dreamcast/+Start Reicast.sh"
OMX: creating 3 buffers
OMX: audio output to 'hdmi'
OMX: underrun occurred
OMX: underrun occurred("OMX: underrun ocurred" this repeats to 960 lines)
Guide used:
https://github.com/RetroPie/RetroPie-Setup/wiki/Dreamcast
https://www.reddit.com/r/RetroPie/comments/3ye3f0/cant_manage_to_configure_dreamcast_controls/File:
/opt/retropie/configs/dreamcast/mappings/controller_MicrosoftX-BoxOneSpad.cfg[emulator]
mapping_name = Microsoft X-Box One S pad
btn_escape = 316[dreamcast]
btn_a = 305
btn_b = 304
btn_c = 311
btn_d = 310
btn_x = 308
btn_y = 307
btn_z = 314
btn_start = 315
axis_x = 0
axis_y = 1[compat]
axis_dpad1_x = 16
axis_dpad1_x_inverted = no
axis_dpad1_y = 17
axis_dpad1_y_inverted = no
btn_trigger_left = 312
btn_trigger_right = 313
axis_x_inverted = no
axis_y_inverted = no===========================================
/opt/retropie/configs/dreamcast/emu.cfg
[audio]
backend = auto
disable = 0[config]
Debug.SerialConsoleEnabled = 0
Dreamcast.Broadcast = 4
Dreamcast.Cable = 3
Dreamcast.RTC = -2128832150
Dreamcast.Region = 3
Dynarec.Enabled = 1
Dynarec.idleskip = 1
Dynarec.unstable-opt = 0
aica.LimitFPS = 1
aica.NoBatch = 0
aica.NoSound = 0
bios.UseReios = 0
pvr.MaxThreads = 3
pvr.Subdivide = 0
pvr.SynchronousRendering = 0
pvr.rend = 0
rend.UseMipmaps = 1
rend.WideScreen = 0
ta.skip = 0[dispmanx]
height = 480
maintain_aspect = yes
width = 640[input]
evdev_device_id_1 = 0
evdev_device_id_2 = -1
evdev_device_id_3 = -1
evdev_device_id_4 = -1
evdev_mapping_1 = /opt/retropie/configs/dreamcast/mappings/controller_MicrosoftX-BoxOneSpad.cfg
joystick_device_id = -1[omx]
audio_hdmi = yes
audio_latency = 100[reios]
ElfFile =[testing]
ta.HashCheckFile =
ta.HashLogFile =[validate]
OpenGlChecks = 0===========================================
/opt/retropie/emulators/reicast/bin/reicast.sh#!/usr/bin/env bash
This file is part of The RetroPie Project
The RetroPie Project is the legal property of its developers, whose names are
too numerous to list here. Please refer to the COPYRIGHT.md file distributed with this source.
See the LICENSE.md file at the top-level directory of this distribution and
at https://raw.githubusercontent.com/RetroPie/RetroPie-Setup/master/LICENSE.md
AUDIO="$1"
ROM="$2"
rootdir="/opt/retropie"
configdir="$rootdir/configs"source "$rootdir/lib/inifuncs.sh"
function mapInput() {
local js_device
local js_device_num
local ev_device
local ev_devices
local ev_device_num
local device_counter
local conf="$configdir/dreamcast/emu.cfg"
local params=""# get a list of all present js device numbers and device names # and device count for js_device in /dev/input/js*; do js_device_num=${js_device/\/dev\/input\/js/} for ev_device in /dev/input/event*; do ev_device_num=${ev_device/\/dev\/input\/event/} if [[ -d "/sys/class/input/event${ev_device_num}/device/js${js_device_num}" ]]; then file[$ev_device_num]=$(grep --exclude=*.bak -rl "$configdir/dreamcast/mappings/" -e "= $(</sys/class/input/event${ev_device_num}/device/name)") if [[ -f "${file[$ev_device_num]}" ]]; then #file[$ev_device_num]="${file[$ev_device_num]##*/}" ev_devices[$ev_device_num]=$(</sys/class/input/event${ev_device_num}/device/name) device_counter=$(($device_counter+1)) fi fi done done # emu.cfg: store up to four event devices and mapping files if [[ "$device_counter" -gt "0" ]]; then # reicast supports max 4 event devices if [[ "$device_counter" -gt "4" ]]; then device_counter="4" fi local counter=0 for ev_device_num in "${!ev_devices[@]}"; do if [[ "$counter" -lt "$device_counter" ]]; then counter=$(($counter+1)) params+="-config input:evdev_device_id_$counter=$ev_device_num " params+="-config input:evdev_mapping_$counter=${file[$ev_device_num]} " fi done while [[ "$counter" -lt "4" ]]; do counter=$(($counter+1)) params+="-config input:evdev_device_id_$counter=-1 " params+="-config input:evdev_mapping_$counter=-1 " done else # fallback to keyboard setup params+="-config input:evdev_device_id_1=0 " device_counter=1 fi params+="-config input:joystick_device_id=-1 " params+="-config players:nb=$device_counter " echo "$params"
if [[ ! -f "$HOME/RetroPie/BIOS/dc_boot.bin" ]]; then
dialog --no-cancel --pause "You need to copy the Dreamcast BIOS files (dc_boot.bin and dc_flash.bin) to the folder $biosdir to boot the Dreamcast emulator." 22 76 15
exit 1
fiparams=(-config config:homedir=$HOME -config x11:fullscreen=1)
getAutoConf reicast_input && params+=($(mapInput))
[[ -n "$AUDIO" ]] && params+=(-config audio:backend=$AUDIO -config audio:disable=0)
[[ -n "$ROM" ]] && params+=(-config config:image="$ROM")
if [[ "$AUDIO" == "oss" ]]; then
aoss "$rootdir/emulators/reicast/bin/reicast" "${params[@]}" >/dev/null
else
fi===========================================
I also used the NullDC trick to try and fix the clock issue. (It edits dc_flash and makes a copy, which you rename and place in the BIOS folder)
reicast_input = "1" in /opt/retropie/configs/all/autoconf.cfg
Emulator: Reicast
How to replicate the problem: I ran the joystick config via command line (reicast-joyconfig) and the joystick was still functional. It was only the joystick, no buttons worked. I had a working joystick until I ran the autoconfig in RETROPIE SETUP.
I've confirmed my controller is at event0. At this point all I can guess is that this controller is just not supported. The config file looks quite a bit like a 360 controller's config provided on the wiki.
