    [SCRIPT] Setup for an automatic savestate selector
    savestatesscript
    47 Posts 13 Posters 11.6k Views
      cyperghost
      @Athimar
      is the file /usr/lib/libraspidmx.so.1 available?
      • jandalf81J
        jandalf81
        @Athimar
        Take a look into ~/scripts/savestate_selector/savestate_selector-install.log, any errors should be listed there.
        You could also try to perform the installation of PNGview manually:
        wget -P ~ https://github.com/AndrewFromMelbourne/raspidmx/archive/master.zip
        unzip ~/master.zip -d ~
        make --directory=~/raspidmx-master
        sudo mv ~/raspidmx-master/pngview/pngview /usr/bin
        sudo mv ~/raspidmx-master/lib/libraspidmx.so.1
        sudo chown root:root /usr/bin/pngview
        sudo chmod 755 /usr/bin/pngview
        rm ~/master.zip
        sudo rm -r ~/raspidmx-master
        This downloads the source code, unzips it, compiles it and then moves the compiled files before removing the temporary files. If this doesn't work, please post either the mentioned log file or any errors the commands above give you.
          jozzy1 @jandalf81
          @jandalf81 hi, THANKS for this great script. just installed and works great. :D
          • shavecatS
            shavecat
            No Battery Save Found ?
            whats that ? :(
            jandalf81J 1 Reply Last reply Reply Quote 0
            • jandalf81J
              jandalf81 @shavecat
              @jozzy1
              Thanks, that's great to hear!
              @shavecat
              Battery saves are the ROM's save games.
              Whenever you use the game's save function, a SRM file will be created. That is the Battery save. The name comes from the fact that these old game cartridges had to contain a literal battery to be able to keep the save even when the console was powered off or the cartridge was removed from the console.
              shavecatS 1 Reply Last reply Reply Quote 0
              • shavecatS
                shavecat @jandalf81
                @jandalf81
                Thanks a lot ,
                cant get to auto save after 10sec by him self...
                and dont see the thumbnails pics save on the savesate load screen :
                everything is on enable&install like it should be.
                what im doing worng ?
                • shavecatS
                  shavecat @shavecat
                  Try again
                  and it worked better.
                  Why is not auto save ? do i need to change in the
                  'retroarch.cfg'
                  the autosave = false , to true ?
                    SuperPitendo
                    Hi,
                    due to some issues I had to make a fresh install of RetroPie. After setting up my system from scratch, I couldn't get your script to work again (completely)...
                    IMAGEMAGICK is not found and it skips the installation. I tried to install it manually via commandline but still with no success.
                    I think this causes the "no-thumbnails-problem" of @shavecat
                    • shavecatS
                      shavecat @SuperPitendo
                      @SuperPitendo
                      Try- sudo apt-get update
                      think it will help.
                      like u said start again , and it worked with the - thumbnails-problem like should be.
                      getting the thumbnails working great ! .
                      but still no auto save ,
                      Is it spouse to auto save by him self on slot 0?
                      or i need to config it ?
                      Cant see on the loading saves stae the auto save state.
                      everything else works great !
                      • jandalf81J
                        jandalf81
                        @SuperPitendo
                        As @shavecat said, try sudo apt-get update before you start my setup script. Imagemagick should still be installable via apt-get which is exactly what my script tries to do... You might have one binary installed still which makes the setup script skip the installation of Imagemagick. Can you check if the file /usr/bin/convert exists?
                        If you still have problems, please post the setup log from ~/scripts/savestate_selector/savestate_selector-install.log
                        @shavecat
                        What do you mean by
                        Are you trying to make RetroArch create a savestate every 10 seconds? If so, that would have to be configured within RetroArch itself, there should be a fitting setting in the "Saving" menu...
                        Are you sure you created a save state? Without them, there's no thumbnail to show as well...
                        • shavecatS
                          shavecat @jandalf81
                          @jandalf81
                          Sorry im stupid got confused a bit .
                          it works great jandalf81 thanks alot with thumbnails works great !
                          love your code Thanks!
                          I have last Q , about the auto save state in the RetroArch with the autosave when i quit i have an auto save with pic' in the folder and all,
                          but cant get it too see in on the load state thumbnails (think cause it look in the code for state, and not auto) im getting like $SRAM_PATH.auto. (for auto saving)
                          is that right ?
                          • jandalf81J
                            jandalf81 @shavecat
                            @shavecat
                            Yeah, I excluded the AUTO savestate because I use that to be able to automatically load a save state from the script. But you can also configure RetroArch to automatically load that AUTO save state when starting the ROM.
                            Alternatively, you could customize the script. Open savestate_selector.sh and navigate to line 203:
                            done <<< $(find $statePath -type f -iname "${romfilebase}.state*" ! -iname "*.png" ! -iname "*.auto") # get all STATE files, exclude *.PNG and *.AUTO
                            Change that to
                            done <<< $(find $statePath -type f -iname "${romfilebase}.state*" ! -iname "*.png") # get all STATE files, exclude *.PNG
                            to not exclude the AUTO save state. Please note that I did not test this. There might (will) be some unexpected side effects...
                            • shavecatS
                              shavecat @jandalf81
                              @jandalf81
                              THANKS !!!! :)))
                                joelkolb
                                @jandalf81 I know this is an old thread but just because something is old doesn't mean it isn't good. I just stumbled upon this while searching to see if anyone had come up with a more NES-Classic-like way of handling save states. I just wanted to say that this is excellent work and thank you.
                                  joelkolb
                                  @jandalf81 Again, I know this is an old thread and hopefully you haven't put this project behind you. I have been playing with your savestate selector and I've run into 2 issues.
                                  The first is with the "Set delay to delete AUTO savestate" option. The default value is 10 seconds but I find that setting this to anything less than 15 will cause loading the selected savestate to fail. A message will show on screen stating that it loaded but in fact it does not. The rom just loads normally. I suspect it usually takes a little longer than 10 seconds for a rom and savestate to load and so the auto savestate is getting deleted before it can be loaded if the value is 10 seconds or less.
                                  The other, bigger issue (because I haven't figured out a workaround) is that it seems like if a rom has a dot in the file name it's savestates will not be detected and the savestate selector dialog will not load. I've tested this with the NES roms 'Mr. Gimmick (Europe)', 'R.C. Pro-Am (USA)', 'Simpsons, The - Bart vs. the Space Mutants (USA)', and 'Super Mario Bros. (World)'. There are definitely savestaes for each of these roms but the savestate selector dialog does not load for any of them. The only common denominator I can see is that they all have dots in their file names.
                                  I further tested this theory by making copies of these roms with the the dots removed from the filenames. I then created new savestates with the renamed roms and then savestate selector dialog came up as expected.
                                  I also tested with roms that had other special characters in their file names like 'Pac-Man (USA) (Namco)' and 'Mike Tyson's Punch-Out!! (Japan, USA) (Rev A)'. These worked with no problem. Of course that isn't a comprehensive test of special characters but I've only experienced this issue with roms with dots in their filnames, not any other special characters.
                                  I'm sure it's just a matter of putting something in quotes or adding an escape character somewhere in your script. Unfortunately I'm not proficient enough in Unix shell scripting to figure it out myself without diving pretty deep. Hopefully you can help me out.
                                    cyperghost @joelkolb
                                    @joelkolb That is easy to fix ... edit the script in line 80
                                    change romfilebase="${romfilename%%.*}" # filename of $rom, excluding extension
                                    to
                                    romfilebase="${romfilename%.*}" # filename of $rom, excluding extension
                                    the double %% strips filename till last . and this is the R in R.C. PROAM
                                      joelkolb @cyperghost
                                      @cyperghost Awesome, thanks! It works like a charm. I knew something of this nature would be an easy fix for someone good with shell scripting.
                                      • shavecatS
                                        shavecat @joelkolb
                                        @joelkolb
                                        Is that fix the issue that some games dont load the save'd file's ?
                                        and if so what file i need to fix.
                                        thanks a lot :)
                                          cyperghost
                                          @shavecat It could be the fix that some games do not load. In the case of R.C.ProAM the autosavestate was renamed wrong to R.autostate
                                          In the case of the 10s time you need a possibility to detect file access. That can be made by lsof -t | grep .autostate or by inotify daemon. So the easiest solution imho here is to extend timer.
                                          • shavecatS
                                            shavecat @cyperghost
                                            @cyperghost
                                            Im Confused :
                                            so i need to change somthing in the files or update ?
                                            how can i do it ?
                                            just some games like in psx loade the save state and give me the loading screen state save , and some dont.
