    System backup and restore (idea and project)
    5 Posts 2 Posters 1.5k Views
    • Drakaen391D
      Drakaen391
      So, with each major change/update I have been backing up my essential files and Roms/saves then updating via script or in some cases, starting it from scratch...
      This last update (3.8.1) has so much updates I have been hoping for that I am just redoing it... But, I will be starting a way to make back up easier, without a bunch of extra programs...
      I do not know about Mac programming, so hopefully someone who does will be willing to port it once I get a working copy up.
      STATUS: Beta version 0.4b
      Platforms: Raspberry pi directly
      Language: BASH
      RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
      Retropie (Latest Stable)
      PiBox with Wind Tunnel Cooling System
        backstander
        I would use this. Are you thinking of having this run on the Pi to push the files to be backed up to another computer on the network or an attached external hard drive, it could even be included with the official RetroPie image. If you're planning to have it run from another Linux or Windows computer to go get the files to be backed up, I'd use it either way.
        • Drakaen391D
          Drakaen391
          It most likely will run directly off the pi due to issues with the Pi's security.... Only file I am having trouble setting up is the config file on the boot partition
          • Drakaen391D
            Drakaen391
            the script will run sorta like this:
            Sudo start
            check for back up location status
            If connected proceed else echo error
            *Chmod back up files for copy privileges
            Start back up with overwrite
            *Once complete chmod files to default
            Echo completion
            Stop
            • Drakaen391D
              Drakaen391
              UPDATE: got an alpha level script written... It's very messy but will make a new thread looking for testers once I get a successful run on the pi itself (runs on Ubuntu)
