Vice C64 controller/key mapping (work around)
Hey folks need a little help with vice controller mapping. I was using a 360 controller and i was able to map keys with no issue. I just changed to an 8bitdo nes30 pro, now when i map a key to say the virtual keyboard all keys are mapped to it. i.e. i map say A to virtual keyboard. A,B,X,Y will be mapped as well. Any ideas, if there a config file i can manually edit???
P.
Just to let 64 8bitdo fans know the key mapping issue if you upgrade the firmware to 1.69 and change the config with the new key mapping it corrects the key mapping to all keys in Vice.
bumping my question I miss my c64 and it was working so beautifully!
So i've been experimenting with no luck so anyone got any ideas I am guessing i have to manually edit the vkm and vjm files but i dont really follow the format totally so even if someone could help with that i would really appreciate it.
There must be some other 8bitdo C64 fans out there ???
Many thanks
Paul
