    8Bitdo FC30 Pro works in ES but not Retroarch
    40 Posts 11 Posters 28.1k Views
      tamper
      Hi,
      Running 3.6 on a Pi2 and trying to setup the 8BitDo FC30 Pro controller. As others have experienced, once paired and configured it works fine in EmulationStation, but not in the emulators themselves. Either the button mapping is wrong, or the controller is completely unresponsive. Which also means there's no way to return to ES other than rebooting.
      I've tried the various setup tutorials I've seen, including the one on the wiki and this one (https://www.reddit.com/r/RetroPie/comments/4d5hcf/how_to_setup_8bitdo_nes30_fc30_pro_controllers_on/) but no luck.
      Anyone successfully got it working? Is it a case of deleting any other/old settings which may be causing a conflict?
      • RionR
        Rion
        I think this thread should be in " Help and Support"
        Anyway have a look at these links
        https://retropie.org.uk/forum/topic/33/nes30-pro-issue-3-6
        https://retropie.org.uk/forum/topic/117/bluetooth-issues-8bitdo/2
        FBNeo rom filtering
        Mame2003 Arcade Bezels
        Fba Arcade Bezels
        Fba NeoGeo Bezels
          tamper
          Yeah, everything links back either to that one YouTube video or the reddit post. Tried both and neither work for me, unfortunately.
          FloobF 1 Reply Last reply Reply Quote 0
          • RionR
            Rion
            Have you also tried changing this in the cfg file?
            input_driver = "udev"
            To
            input_driver = "sdl"
            FBNeo rom filtering
            Fba Arcade Bezels
            Fba NeoGeo Bezels
            • FloobF
              Floob @tamper
              @tamper said in 8Bitdo FC30 Pro works in ES but not Retroarch:
              Can you post your controller file that is in /opt/retropie/configs/all/retroarch-joypads/ onto pastebin.com so I can read it?
                tamper
                Sure - it's here : http://pastebin.com/7nQNgBh6
                • FloobF
                  Floob @tamper
                  @tamper Can you try this one?
                  http://pastebin.com/raw/i3atsUbc
                    tamper @Floob
                    @Floob Still no luck :( The FC30 Pro runs fine up until the emulator actually loads, then nothing.
                    A USB-connected SNES-style pad works (almost) fine, so the problem must be specific to the FC30.
                    (I say almost fine - the ability to return to ES with start+select seems to have gone away completely even from the wired pad).
                    • FloobF
                      Floob
                      Which emulator are you trying? Use the Megadrive as a test option, make sure you are using a libretro based one.
                      Which firmware version are you using on the FC30 Pro - and how are you turning it on - just holding the power button on the base?
                        DavidIQ
                        Just want to jump in and say that I'm having the same exact problem using the same hardware. The NES30 controller (or FC30 controller, I have one of each) is paired and working fine with ES but not with the games. Some of the Game Boy Color games I have respond at least to the D-Pad, but the A and B buttons seem to have mapped themselves to Select and Start.
                          tamper @Floob
                          @Floob Thanks Floob. I'm using 1.59 firmware on the FC30 Pro. Tried with MegaDrive, NES, and SNES - all the same results. And turning on the FC30 Pro with just the power button only.
                          Pairing is no problem in ES, which makes me think I'm turning it on correctly.
                            tamper @DavidIQ
                            @DavidIQ Hey DavidIQ, might help you to know that the FC30 and the NES30 are not the same as the FC30 Pro, especially when it comes to configuration. If you're looking up settings for the FC30 Pro, that might be where you're having trouble.
                            • FloobF
                              Floob @tamper
                              @tamper If you have updated your controller file correctly, can you try the 1.58 firmware?
                              Thats the only difference left between my setup and yours I think.
                              Bear in mind that ES and Retroarch use different files to map the controller.
                              Maybe you can use jstest to confirm your buttons are reporting as they should.
                              I'm also assuming you havent tweaked any retroarch.cfg files.
                                palbrecht @Rion
                                @Rion said in 8Bitdo FC30 Pro works in ES but not Retroarch:
                                To
                                Same Problem with the NEs30 but after i edited the file "/opt/retropie/configs/all/retroarch.cfg"
                                and replace the "udev" with "sdl". After that, it works perfekt!
                                I have the firmware 1.69 and a fresh clean install of Retropi 3.7.
                                The Udev missconfigured the keys, i thing.... When you look at your "/opt/retropie/configs/all/retroarch-joypads/8BitdoNES30Pro.cfg" file, you will see that the Start Button is on 22. But when you test your Controler with "jstest /dev/input/js0" you can see that is the button 11.
                                After i set the udev to sdl the bindings are okay now.
                                http://pastebin.com/Qdi5pivh
                                  DavidIQ @tamper
                                  Nah as I said it's the same exact hardware. I simply left out the pro part by accident, but it's the same controller. Also the firmware on mine is 1.69. This problem seems to be happening to a few others with the latest RetroPie and the 8Bitdo controllers. There's a few comments on the YouTube videos. I'll try switching the input_driver setting and see if that takes care of it.
                                  • FloobF
                                    Floob
                                    What happens if you set these values in /opt/retropie/configs/all/retroarch.cfg
                                    # Input driver. Depending on video driver, it might force a different input driver.
                                    # input_driver = sdl
                                    # Input device driver. (Valid: linuxraw, sdl, dinput)
                                    input_joypad_driver = "udev"
                                    to
                                    # input_driver = udev
                                    Does the file I posted work then?
                                    I'm not suggesting this is an ideal fix, but I'm just trying to see where the problem is occurring.
                                    I really need to find mine to test it out in 3.7 now.
                                    • RionR
                                      Rion
                                      Same problem here.
                                      Chang from udev to sdl in
                                      Change's nothing and it reverts back to udev when you restart and creates a "8BitdoNES30Pro.cfg.backup" file. So you have to make the changes in Retroarch.cfg.
                                      Have not tried to add your changes that you posted yet.
                                      FBNeo rom filtering
                                      Fba Arcade Bezels
                                      Fba NeoGeo Bezels
                                        BuZz administrators
                                        @Floob does udev work for you when generating config with latest retropie-setup ? I did change the strings we check for have for "renumbering" for udev, but perhaps I broken something (I simplified it by using wildcards).
                                        Please can you all post me your ~/.emulationstation/es_input.cfg files
                                        • FloobF
                                          Floob @BuZz
                                          @BuZz I'll get a clean 3.7 and find my FC30 Pro tonight.
                                          I'll post up the resulting files.
                                          • FloobF
                                            Floob
                                            Ok, just ran through it. Seems fine to me?
                                            My resulting button codes seem to match these:
                                            https://github.com/libretro/retroarch-joypad-autoconfig/blob/master/udev/8Bitdo-FC30-Pro-GamePad-Bluetooth-Mode(POWER)-Mode(POWER%2BR1).cfg
                                            • Clean 3.7
                                            • Used FC30 Pro (Firmware 1.68)
                                            • Auto restarted to resize
                                            • F4 to CLI from ES
                                            • Followed manual bluetooth steps #1 and #2 here:
                                              https://github.com/retropie/retropie-setup/wiki/Setting-up-a-Bluetooth-controller
                                            • Didnt update RetroPie script, just used 3.7
                                            • Paired and connected to the FC30Pro without issue (although name didnt appear during the setup just the MAC)
                                            • went back to ES from the CLI (as opposed to rebooting as I can never get ES to reconnect to BT without forcing it)
                                            • Configured joypad in ES
                                              For some reason it doesnt detect the R2/L2 buttons although I'm sure it used to.
                                            As an aside it is logging that there is no .srm when I start a game
                                            retro_read_file: Failed to open /home/pi/RetroPie/roms/megadrive/Sonic The Hedgehog (W) (REV01) [!].srm: No such file or directory
                                            Ran about 4 MegaDrive games with picodrive and all seemed to detect my buttons and hotkeys without issue.
                                            /opt/retropie/configs/all/retroarch-joypads/8BitdoFC30Pro.cfg
                                            http://pastebin.com/raw/u69cDDJ4
                                            es_input.cfg
                                            http://pastebin.com/raw/jDPPkCsA
                                            es_temporaryinput.cfg
                                            http://pastebin.com/raw/QSk48vyA
                                            es_log.txt
                                            http://pastebin.com/raw/hB3qhiQ6
