Little big adventure 2 problem
@mitu cant because i have to do CTRL F1 but i dont know where is the CTRL buttons
O dont know what to do.. on recalbox it was working i just add mapperfile=lba2.map
I try to do this on retrpie but it doesnot work
@espegael said in Little big adventure 2 problem:
This works if you have that file available, which I assume is not the case on RetroPie. Maybe it's generated automatically by Recalbox or by auto-configured based on something else, but here you need to use the Mapper, re-map the keyboard and save the file, which you can then reference in the
.conf
withmapperfile=<save_file>
@mitu ok right it finally works. I found the CTRL and F1buttonns and configure the keymap
It works on everythink except on the number pad.. i think there is a problem with the NUM bouton. I see that the NUM led dont light when i push it.. i test on another key and its the same... my configuration configures the page up bouton and not the 8 bouton i think
The same problme appears with CAPS bouton, does raspberry support the changing of CAPS and NUM
it ligh on my computer but not in the raspberry
