    Problem Super Kintaro URSUS dont work
    super kintaroursus
    5 Posts 3 Posters 559 Views
    • E
      espegael
      hello friends
      i just received my new raspberry'sbox, the super kintaro URSUS
      i installed it in the terminal with this command
      sudo wget -O - https://goo.gl/22RsN3 | bash
      like it was written on the manual
      but it does nt work, i can power on the pi, but i have no led, no reset possible
      at the en,d of installing it says an error occured
      pkg: unrevorerable fatal erro, aborting
      sub process /usr/bin/dpkg returned an error codev (2)
      it seem the installon does not complete. i don't know if there is another solution to install it
      for information i have also a recalbox system on another sd cards and usb key (because i like to sxith on diffrerent system) , and i could install it using this
      https://github.com/MichaelKirsch/Kintaro-Recalbox
      and it works fine
      maybe on retropie is it possible too
        You should ask the creator of the script for support. This is not a RetroPie problem, but a problem with the Kintaro script.
          snock
          @espegael said in Problem Super Kintaro URSUS dont work:
          super kintaro URSUS
          curl -s https://packagecloud.io/install/repositories/kintaro/pcb/script.deb.sh | sudo bash
          • E
            espegael @snock
            @snock what is that? I dont understand. Is this the sxript for retropie?? Where i have to put it in etc/init d??
              snock
              execute it from terminal. Tutorial -> https://packagecloud.io/kintaro/pcb/install
