    Retroarch problem
    retroarchproblem
    28 Posts 3 Posters 1.6k Views
    • N
      Niklassen @mitu
      @mitu Ok, most problems are fixed. I can play n64 games, and all games that use the full controller. But snes and nes games still have the same problem, buttons are configured wrongly, and my configuration does not affect it. I have the same exit problems there too. Any fixes?
      ClydeC mituM 2 Replies Last reply Reply Quote 0
        Clyde @Niklassen
        @Niklassen Two things come to my mind:
        • Maybe you have saved core overrides in RetroArchs "Quick Menu" -> "Controls". If so, there is a menu entry to delete the override.
        • The joysticks may be not assigned to the proper player numbers. There is a joystick selection tool from @meleu to assign them conveniently.
          mitu Global Moderator @Niklassen
          @Niklassen Did you select a Hotkey when configuring the controller OR chose to use Select as controller, when you configured it in Emulationstation ? Are you able to enter the RetroArch GUI with Select + X (or Hotkey + X) ?
          Is the buttons not working problem the same as before - i.e. the same buttons - or this is different ?
          • N
            Niklassen @mitu
            @mitu I managed to get a hot key working. Hotkey+X results in a freeze, just as any other interactions with retroarch. That problem did not fix itself, even after installing the OS again. I now can exit games, and play normally in emulators that uses all the buttons on my controllers. But nes and snes games have the same problem. Home is jump, and so on. If that is fixed, there will only be one problem left, THE VOLUME! It’s so loud, and my headset doesn’t have a volume switch. Changing the system volume won’t do anything. If we resolve those two problems, my portable pi is ready as pie.
              @Niklassen said in Retroarch problem:
              What's Home got to do with it ? Did you map the A/B buttons ? Aren't you able to jump with A or B ? Please do the test for buttons with jstest as I indicated before and see if they match the RetroArch configuration file.
              For the audio problem - configure your from RetroPie system in Emulationstation to use the 3.5' Jack (which I suppose you're using to get the audio) and see if you can control the volume.
              N 3 Replies Last reply Reply Quote 0
              • N
                Niklassen @mitu
                @mitu Home is a button the controller has, which I use as the hotkey. For some reason, that is jump in snes and nes emulators, and probably genesis as well. Will try that test thing now. And no, can’t jump with any other button.
                • N
                  Niklassen @mitu
                  @mitu Yes, my configuration is correct. I can play all emulators that has the same amount of buttons as my ipega. The problem was with older games, the buttons are mapped the same no matter what I do.
                  • N
                    Niklassen @mitu
                    @mitu Update! I found out that I only get the retroarch problem when I use the ipega controller. I never get problem with any other controllers. Using another controller, a managed to get my ipega to work... success!
