    Pi3 force_Hdmi issue/ Picture/ Sound
    hdmiforce
    12 Posts 4 Posters 538 Views
      Asha1980
      hello all,
      I'm a reaI beginner to RPi and the whole workings, so i have a Raspberry Pi 3 running 4.4 and using Retropie i recently built a bartop arcade using a 20" lcd screen, i've all my games running great on there. The power setup is a 2 socket lead which has both the tv and pi plugged in to it(both are powered together).
      Then i realised when i power both the tv and the Pi on, my tv doesn't recognise the Hdmi lead from the pi, so i have to turn the Pi back off then all works.
      i found a help page regarding adding 2 lines to /boot/config.txt file, they are hdmi_force_hotplug=1 and hdmi_drive=2 so i did that and rebooted the pi.
      Everything seemed to start up, which was great. But then i noticed i no longer had any sound and the picture looks really crappy with lines all through it.
      I then went back to the config.txt file and deleted the hdmi_drive=2 line out and my sound came back. But i still have a really terrible picture.
      I've also realised that if i restart the system after the initial boot up the picture becomes clear again, i ideally don't to have to restart the system everytime
      Hope there is something i can do to get the picture back to how it was, a nice clear display, and have the pi power up the same time as the screen.
      sorry for babbling on
        Try adding hdmi_force_edid_audio=1 in addition to the other commands, this might restore your audio settings. You can also force a specific resolution in the config.txt- see these instructions. It seems your monitor doesn't cooperate very with the Pi HDMI detection, so you might try to set explicitly the resolution via the hdmi_group/hdmi_mode parameters - https://www.raspberrypi.org/documentation/configuration/config-txt/video.md.
        A ClydeC 2 Replies Last reply Reply Quote 0
          Asha1980 @mitu
          @mitu thank you for the reply, I'll give it a go later. One more thing am I editing this in the right place.
          I press f4 on my keyboard and type
          sudo nano /boot/config.txt
          Thanks again
            mitu Global Moderator @Asha1980
            @Asha1980 said in Pi3 force_Hdmi issue/ Picture/ Sound:
            If you're asking if this is the right way to edit the config.txt file, then yes.
              Asha1980 @mitu
              @mitu yes i was thankyou,
                Clyde @mitu
                @mitu said in Pi3 force_Hdmi issue/ Picture/ Sound:
                @Asha1980 You may also need to disable EDID detection alltogether, as I had to do when my hdmi splitter required that I turn the Pi on, then off, and then on again after the Pi was powered off for more than half an hour or so. You can disable EDID detection by adding this line to your /boot/config.txt:
                hdmi_ignore_edid=0xa5000080
                This is also mentioned in the link that @mitu gave you, but it can easily been overlooked.
                edit: just some small corrections in my wording. :)
                  edmaul69 @Asha1980
                  This post is deleted!
                    Asha1980
                    many thanks for the advice. I may be back asking more questions if i fail to sort it . As i probably will
                    thanks
                      Asha1980
                      thanks for the advice all. worked first time.
                      thanks
                        Clyde @Asha1980
                        @Asha1980 Glad to hear that. Care to share your exact solution for others? :)
                          Asha1980
                          After taking the advice of some rather helpful people on here, here's how i managed to get my Pi3 to turn on once the tv/monitor was powered on.
                          While in Retropie press f4 on your keyboard to force close retropie , which then will bring up the page to where you access the config.txt file which you will need to edit.
                          Type the following sudo nano /boot/config.txt that will the open up the config.txt file, then scroll to the bottom and type the following hdmi_force_hotplug=1 press enter then type hdmi_force_edid_audio=1 and then finally this hdmi_ignore_edid=0xa5000080 save the file and then reboot Pi,
                          I found everything was working perfect.
                          apologies if this doesn't read very well
                          many thanks all
                            Clyde
                            Thanks for sharing your solution. As for readability, it helps to put commands etc. in single grave accents (`) to highlight them and use a fixed-width font like this.
                            See the Markdown syntax for more formatting options. It's also linked at the upper right corner of the input area of a new post (the small grey "compose").
