    Video preview not working after dist-upgrade (though i can hear the audio)
    raspberrypi3b+videopreviewbrokenafterupdatelogattached
    23 Posts 7 Posters 3.2k Views
      mha @5schatten
      @5schatten How to install, is it possible thru raspberry setup script?
      5schatten5 1 Reply Last reply Reply Quote 0
      • 5schatten5
        5schatten @mha
        @mha said in Video preview not working after dist-upgrade (though i can hear the audio):
        I guess if you use Raspbian you'll get a patches vlc version from the repository. I compile my LibreELEC fork myself & use the patch set for my vlc lib that is used by Emulationstation.
        • TripleMusedT
          TripleMused
          I think I found another solution--I had the same problem. I converted the videos using Handbrake on its normal preset, and now they run fine with both sound and video. They run best using the OMX Player. I only converted about 70 videos, but they all show the previews correctly now.
          Something like this happened before with the videos from Stephen Selph's scraper, so I just thought I would try it and it worked!
