    Trackball was not recognized - possible Solution!
    trackball issue
    1 Posts 1 Posters 324 Views
    • OliBO
      OliB
      Maybe you facing the same problem to get a no-name - mini USB Trackball working in MAME cores even though a standard Mouse is working perfect.
      First go to command line an type:
      lsusb
      you should get a result like this:
      us 001 Device 004: ID 13ba:0018 PCPlay Barcode PCP-BCG4209
      Bus 001 Device 005: ID 0810:e001 Personal Communication Systems, Inc.
      Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
      Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
      Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      In my case, the first line is representing my Trackball.
      Next, note down this parts of the string:
      13ba and 0018 (take yours no mine - this is only a example!) This 4 digits each represents the Vendor an Device ID.
      Then edit the cmdline.txt in the boot folder and ad the following line
      usbhid.quirks=0x13ba:0x0018:0x040 (remember: use your digits here discovered from above)
      Attention: Add this string in the same line at the very end of the last digit and with a space.
      Hope this helps.
