    copy controller cfg to psx`?
    psx
    21 Posts 3 Posters 962 Views
    • N
      naddel81
      hi at all,
      I configured my controller for all emulators using retroarch. unfortunately that will not work on PSX.
      here is my configfile from /all joypads. how can i copy it to psx since I cannot do it in the emulator. no button is recognized by default. why does it not use the same cfg all the other emulators use?
      "input_device = "Gamepad"
      input_driver = "udev"
      input_r_y_plus_axis = "+3"
      input_r_x_minus_axis = "-2"
      input_l_btn = "8"
      input_load_state_btn = "8"
      input_start_btn = "11"
      input_exit_emulator_btn = "11"
      input_r_y_minus_axis = "-3"
      input_down_btn = "h0down"
      input_l_x_plus_axis = "+0"
      input_r_btn = "9"
      input_save_state_btn = "9"
      input_right_btn = "h0right"
      input_select_btn = "10"
      input_left_btn = "h0left"
      input_l2_btn = "6"
      input_l3_btn = "13"
      input_l_y_minus_axis = "-1"
      input_up_btn = "h0up"
      input_a_btn = "1"
      input_b_btn = "0"
      input_reset_btn = "0"
      input_enable_hotkey_btn = "10"
      input_l_y_plus_axis = "+1"
      input_r2_btn = "7"
      input_r3_btn = "14"
      input_x_btn = "4"
      input_menu_toggle_btn = "4"
      input_l_x_minus_axis = "-0"
      input_y_btn = "3"
      input_r_x_plus_axis = "+2"
        Which emulator are you using ?
        • N
          naddel81
          lr-pcsx ... the standard one on the retropie 4.4.4
            mitu Global Moderator @naddel81
            @naddel81 What does 'not working' mean ? No buttons work ? Does the RGUI toggle (Select + X) work ? Have you done anything special for the PSX system (like saving a configuration file for it ) ?
            • N
              naddel81
              I cannot even enter the main menu. that works in every other emulator. what file do I have to copy over or delete to make it work in PSX, too?
                @naddel81 Why do you think you need to 'copy' or 'remove' files to fix this problem ? Can you attach a RetroArch log file (/dev/shm/runcommand.log) taken with verbose logging when starting a PS1 game ? Get the file's contents and post it on pastebin.com, it should be too large for the forum.
                • N
                  naddel81
                  it seems psx controls are not taken over from the global retroarch settings.
                  cant I just delete copy over the global cfg to this /opt/retropie/configs/psx/retroarch.cfg ?
                  I have FTP access to the pi. where is the file located that you need?
                  • N
                    naddel81
                    Parameters:
                    Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Tekken 3 (USA).cue" --appendconfig /dev/shm/retroarch.cfg
                    Memcard 2: disabled
                    Starting PCSX-ReARMed
                    Running PCSX Version 1.9 (Oct 13 2018).
                    psxMap: warning: wanted to map @80000000, got 0x6f560000
                    Init new dynarec
                    testing if we can run recompiled code..
                    test passed.
                    warning: RAM is not directly mapped, performance will suffer
                    Mapped (RAM/scrp/ROM/LUTs/TC):
                    77000000/1f800000/1fc00000/08000000/701a5000
                    no BIOS files found.
                    RGB565 supported, using it
                    plugin: plugins/builtin_gpu
                    plugin: plugins/builtin_spu
                    plugin: plugins/builtin_pad
                    Plugins loaded.
                    Loaded CD Image: /home/pi/RetroPie/roms/psx/Tekken 3 (USA).cue[+cue].
                    Track 01 (DATA) - Start 00:02:00, Length 59:45:59
                    Track 02 (AUDIO) - Start 59:49:59, Length 02:35:03
                    Track 03 (AUDIO) - Start 62:26:62, Length 02:36:73
                    selected sound output driver: libretro
                    CD-ROM Label: TEKKEN3
                    CD-ROM ID: TEKKEN3SL
                    CD-ROM EXE Name: TEKKEN3\SLUS_004.02;1
                    ari64_reset
                    note: running with HLE BIOS, expect compatibility problems
                    Failed to open /home/pi/RetroPie/roms/psx/Tekken 3 (USA).srm: No such file or directory
                      @naddel81 said in copy controller cfg to psx`?:
                      I just posted above the location. From the log file you posted, it seems you don't have a BIOS file - you should fix that first. Also, the log would be better to be with verbose logging enabled from the Runcommand launch menu.
                      • N
                        naddel81
                        will try. just pulling the power plug again :(
                        • N
                          naddel81
                          although I have all the bios files in the BIOS folder and additionally in BIOS/psx it still tells me there is no BIOS found? is that not the right folder?
                          • N
                            naddel81
                            https://pastebin.com/gPrDQ4X2
                              @naddel81 Either your psx RetroArch or global RetroArch is wrong.
                              [WARN] SYSTEM DIR is empty, assume CONTENT DIR /home/pi/RetroPie/roms/psx/Tekken 3 (USA).cue
                              [INFO] Environ SYSTEM_DIRECTORY: "/home/pi/RetroPie/roms/psx/".
                              That's why the BIOS is not found and probably that's why the mapping doesn't work, although I see some auto-configuration taking place.
                              Replace the psx system retroarch.cfg with
                              input_remapping_directory = "/opt/retropie/configs/psx/"
                              in the /opt/retropie/configs/psx folder and try again.
                              You either enabled Save on Exit in RetroArch or just saved your configuration from the RGUI when you started a psx game. Are you using a stock RetroPie image ?
                              • N
                                naddel81
                                yes, I did save on exit. now I copied the global /all retroarch.cfg to the psx folder and replaced the old one. it seems to be working fine now. how can I prevent this from happening again?
                                thanks for your help!!!
                                  Don't use save ? Also, this is not what I recommended you to do, so YMMV.
                                  • N
                                    naddel81
                                    @mitu said in copy controller cfg to psx`?:
                                    YMMV
                                    but when I don`t save I have to recreate the settings every time I play. that is "enhance resolution" etc.
                                    btw: does it really double the geometry resolution (not textures) so it is 2x antialiasing? I do not see a difference in enhanced and normal resolution. only bilinear filtering has a visible influence on the visual quality. do I have to restart for it to take effect?
                                      @naddel81 Those are Core Options and are saved automatically into a different file - you don't need to save them.
                                      • N
                                        naddel81
                                        good to know. so "save on configuration" is OFF for my own safety, right? ;)
                                        is there an option to see the CPU load in retroarch? I would like to test the influence of different graphical settings on the system load.
                                          Clyde @naddel81
                                          You can display the FPS in the RetroArch GUI unter Settings > Onscreen Display > Onscreen Notifications.
                                          edit: Also, if you use the Retropie image for the Pi or installed on any other kind of Linux system, you could ssh into it and use the command top to see the system load of the retroarch process. You can stop top by pressing the q key.
                                          • N
                                            naddel81
                                            great, will try that. because pure FPS does not tell the system load. it could be the game and/or emulator that is not running smooth at a constant framerate. but with system load I can clearly see if my CPU or GPU are at maximum.
