    Logitech wireless keyboard K360 & K400+, works in Pi but not in Retropie
    logitech
    4 Posts 3 Posters 946 Views
      bichoman666
      Hi all,
      I have plugged a Logitech wireless keyboard in my Pi3. It works in console and menu of Pi3, but doesn´t work in Retropie (tried with Logitech models K360 and K400+)
      How can I set it in Retropie??
      Thanks for your help. Regards
        mitu Global Moderator @bichoman666
        @bichoman666 There's not set-up to do, if it's recognized by the OS (Raspbian), then it should work in Emulationstation also. What do you mean by does not work ? Please add some info about your set-up as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
          bichoman666
          Thanks for your answer. Sorry, I´ll explain better
          The problem is in EmulationStation dashboard, and neither works wired keyboard (only joysticks), but when I access to Retropie Setup, keyboards works fine (wired and wireless). Trouble is in EmulationStation.
          INFO:
          • Raspberry Pi3 B
          • Retropie version: 4.1.14
          • Power supply: 5V
          • Built from: Nacho Image (Pre made SD website)
          Thanks!
          • V
            VictimRLSH
            "Built from: [Deleted this reference myself] (Pre made SD website)" This site only supports the RetroPie images hosted here. I use the K400+ and mine has no problem working as a controller from ES.
            Download and burn the SD image hosted on this site, and not only is it likely to work, but we will actually be able to support it!
            https://retropie.org.uk/download/
            EDIT: I just noticed that is a pre-made image site complete with copyrighted games included in the image, so removed my reference to it from your quote. Links or mention of images or sites distributing copyrighted games and/or BIOS images are also not allowed here....
            System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
