    RetopiePSX emu problem
    3 Posts 3 Posters 1.1k Views
      recovery
      Hello, i have the retopie 3.8.1 and allready all is installed, moved the romes an by starting the psx symulation it works. Then i istalled all updates for the retro setup and now is no psx symulation on the screen. all others emulations i can see
      • herb_fargusH
        herb_fargus administrators @recovery
        @recovery this goes in help and support. I've moved it. You need .cue files for your .bin files.
        • FloobF
          Floob
          @recovery As herb_fargus says, its probably because when you updated it picked up this change:
          https://github.com/RetroPie/RetroPie-Setup/commit/37857f0ebb2a46379227197bac7a954a3aae15c0
          That means that you must have a corresponding .cue file for your PSX bin files
          You can use this guide to create one:
          http://www.shivaranjan.com/2007/01/03/how-to-create-cue-file-for-a-bin-file-in-5-steps/
          Or you can create one with this tool:
          http://www.dslreports.com/r0/download/373724~1e45059000cfc371c157f544cc5aef07/MakeCue.zip
          @administrators
          I think I'm right in saying that if you run a .bin it will pick up the .cue if it exists - certainly works with WipeOut 2097 anyway.
          On that basis, would it be easier to remove .cue instead of bin, then single track games without a cue sheet will still appear?
