    Skyscraper help.
    scraperskyscrapergameromsscraping newbie
    3 Posts 2 Posters 828 Views
      MosaicDragon
      Official image, rpi 3b , multiple wired and wireless controllers.
      Ive decided to use skyscraper as the built in scraper is lucky to pick up 20% of my games.
      Skyscraper seems to be doing better- perhaps 90% of my 10000 roms but with about 10% still remaining unanswered that equates to about 1000 roms left without a description. I read somewhere that skyscraper can merge results from different databases but im not sure how that works or how to do it?
      Fyi- all my games had description etc until i reset my pi.
      Any advice or recommendations?
        mitu Global Moderator @MosaicDragon
        @MosaicDragon said in Skyscraper help.:
        Read the documentation on how to use Skyscraper ? It has pretty good information on how to use it and combine multiple data sources - see for instance https://github.com/muldjord/skyscraper/blob/master/USECASE.md
        And how did you scrape that information ?
          MosaicDragon @mitu
          @mitu i read it but was unsure as i really dont want to scrape each emulator seperately as per ( Skyscraper -p snes -s screenscraper) suggests. also i was wondering if that same thing could be done from the graphical interface. If not what command syntax would i use to scrape all roms/emulators?
          Originally i think i used the built in scraper from emulationstation and it scraped almost all of them but this time it did barely any.
