    Artwork from Scraper and SkyScraper do not display
    scraper
    9 Posts 2 Posters 1.1k Views
      mobebk
      I don't see the artwork displayed for each game that I have scraped already.
      I downloaded a few themes and they all display fine. I have run both scrapers and they seem to work as they successfully run and I do see the game list.xml populated correctly, but nothing is displayed on the artwork. Ive tried running scraper and skyscraper as sudo from RetroPie setup script from command line as well as directly from skyscraper binary with no luck. I just removed the logs and booted up to have fresh logs. Any help would be extremely appreciated, thanks in advance.
      ORA 1.5.2
      Built From: (Stock XU4-ORA-Base-RP-PUB-v1.5.2.img )
      Here is whats in my es_log:
      https://pastebin.com/3XjAQGSJ
      lvl2: EmulationStation - v2.7.6rp, built Jan 5 2019 - 07:32:14
      lvl2: Creating surface...
      lvl2: Created window successfully.
      lvl2: Added known joystick Pro Controller (instance ID: 0, device index: 0)
      lvl2: Added unconfigured joystick HID 057e:2009 (GUID: 030000007e0500000920000011010000, instance ID: 1, device index: 1).
      lvl2: Added unconfigured joystick HID 057e:2009 (GUID: 030000007e0500000920000011010000, instance ID: 2, device index: 2).
      lvl2: Checking available OpenGL extensions...
      lvl2: ARB_texture_non_power_of_two: MISSING
      lvl2: Loading system config file /home/pigaming/.emulationstation/es_systems.cfg...
      lvl1: Warning from theme "/etc/emulationstation/themes/steampunk/3do/theme.xml"
      (from included file "/etc/emulationstation/themes/steampunk/3do/../theme.xml")
      could not find file ""
      lvl1: Warning from theme "/etc/emulationstation/themes/steampunk/auto-favorites/theme.xml"
      (from included file "/etc/emulationstation/themes/steampunk/auto-favorites/../theme.xml")
      lvl1: Warning from theme "/etc/emulationstation/themes/steampunk/auto-lastplayed/theme.xml"
      (from included file "/etc/emulationstation/themes/steampunk/auto-lastplayed/../theme.xml")
      lvl1: Warning from theme "/etc/emulationstation/themes/steampunk/custom-collections/theme.xml"
      (from included file "/etc/emulationstation/themes/steampunk/custom-collections/../theme.xml")
      Here is one of my game list.xml
      <?xml version="1.0"?>
      <gameList>
      <game>
      <path>./Crazy Taxi.cdi</path>
      <name>Crazy Taxi</name>
      <desc>Crazy Taxi is an arcade-like racer where the player takes the role of a taxi driver who weaves his way through crowded streets, across sidewalks and even under water, in a wild and frantic race to deliver passengers on time. The courses are largely set inside cities crowded with general traffic and pedestrians (which can't be run over, they dive away). The main goal is to bring as many customers as possible to their destination in time. Available customers are marked through circles and the colour represents the distance and the fare they offer. Green means long rides with plenty of money, and red ones are very short.</desc>
      <image>/home/pigaming/.emulationstation/downloaded_images/dreamcast/Crazy Taxi-image.jpg</image>
      <rating>1</rating>
      <releasedate>20000124T000000</releasedate>
      <developer>Hitmaker</developer>
      <publisher>Sega</publisher>
      <genre>Racing</genre>
      <players>2</players>
      </game>
      </gameList>
        mitu Global Moderator @mobebk
        @mobebk Please use pastebin.com for large text logs or files. Can you make sure the correct gamelist is used by Emulationstation ?. Where did you instructed the scraper(s) to save the gamelist ?
          mobebk
          I will def use paste bin now. That one is dreamcast xml file located here (mounted as a shared Volume) :
          /Volumes/configs/all/emulationstation/gamelists/dreamcast/gamelist.xml
          I didn't instruct to save anywhere so it must be the default location? I dunno
            @mobebk Emulationstation can read the gamelist.xml for a system from multiple locations, but only 1 gamelist will be loaded, whichever comes first.
            • the system ROMs folder.
            • ~/.emulationstation/gamelists/<system>
            • /etc/emulationstation/gamelists/<system>
            The file you opened (/Volumes/.., I assume you opened it on macOS) is the file from the 1st location. Check that you don't have another gamelist.xml file in the ROMs folder - if there is one, rename it and restart Emulationstation.
              mobebk @mitu
              @mitu said in Artwork from Scraper and SkyScraper do not display:
              I renamed the gamelist.xml to agamelist.xml in one of the roms folder, rebooted and still doesn't display for that system. I verified that there wasn't another created in the rom folder too if that helps
                @mobebk Then I have no idea why it doesn't work.
                Check if the images are ok on the disk - the ones referenced by the gamelist.xml and double-check again that you don't have duplicate gamelists. You can even remove - for a system - any gamelists and then re-scrape with Skyscraper to see if the gamelist is generated back.
                  mobebk @mitu
                  Thanks, Ill try that out. I don't have any in /etc/emulationstation/gamelists/<system>. fwiw
                    mobebk @mitu
                    I uninstalled sky scraper and all the gamelist.xml files and images, reinstalled skyscraper and ran to download to roms folder. I only see the gamelist.xml in the rams folder now, not in duplicate places, but it still does not display
                      mobebk @mobebk
                      I actually got it working! I don't know how, but I switched from basic to detailed to video and all of a sudden it started working. Thx again for the help
