    Scraper from "retropie-mount" on a USB drive
    scrapermount drive
    3 Posts 2 Posters 393 Views
      CaptainA178
      When I run the scraper on my Pi, nothing works due to my ROMS being on the USB mounted drive. How do I scrape these ROMS with Retropie?
        If you're using the internal ES scraper, most likely it's because of this and not because your ROMs are on an external drive.
          CaptainA178
          I'll try that. Thank you.
