    2 8bitdo bluetooth controller problem
    3 Posts 2 Posters 5.4k Views
      theplanone
      Hi I have 2 8bitdo controllers, one is the FC Pro and the other is the NES Pro. Thanks to Floob's YouTube tutorial and all of your tutorials I was able to connect the first one no problem. The second remote I have successfully connected via bluetooth as well, however it is not being recognized when I try to map the keys in EmulationStation. I am at a loss why the first one works but the second does not. Any idea what I could have done wrong?
      PS:Both controllers auto connect via bluetooth when I start the Pi (blue light indicator)
      Pi Model: (3)
      RetroPie Version Used: (3.6.0)
      Built From: (SD Image)
      USB Devices connected: keyboard
      Controller used: 8bitdoFC30 Pro, 8bitdoNES30 Pro
      Error messages received:
      Guide used: Floob YT tutorial and Wiki
      my 10-local.rules file
      SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 Pro", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
      SUBSYSTEM=="input", ATTRS{name}=="8Bitdo FC30 Pro", MODE="0666", ENV{ID_INPUT_JOYSTICK}="2"
        theplanone @theplanone
        @theplanone when I go to command prompt I see alot of text about SDL
        • F
          FreakyBigFoot
          Follow my guide. https://www.reddit.com/r/RetroPie/comments/4d5hcf/how_to_setup_8bitdo_nes30_fc30_pro_controllers_on/
