    Select and Start not Work: "starting movie record..."
    retroarchselect buttonjoystick mappin
    5 Posts 3 Posters 910 Views
      Run the Jewels
      Hello everyone, I hope to own help me.
      I have retropie mounted in a picade hat 2018.
      The problem is, after emulationstation joystick configuration, when you start a game the select button returns me a message on the screen: "starting the movie record in retropie".
      If I press "coin", he throws me out of the game.
      Are you coming to a better configuration?
      I have no chance to enter Retroarch's "graphical interface". Is not possibile to choose "Retroarch" emulationstation but only "Retroarch Net Play".
      Please help me.```
      code_text
        mitu Global Moderator @Run the Jewels
        @Run-the-Jewels said in Select and Start not Work: "starting movie record...":
        That doesn't sound like a stock RetroPie configuration - are you using the RetroPie image from retropie.org.uk/download ? Please add more info about your system, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        • L
          lupsyn
          Same issue here on my picade once i press the select button with the latest img from the github repo : https://github.com/RetroPie/RetroPie-Setup/releases/download/4.6/retropie-buster-4.6-rpi4.img.gz . Any idea where to look ?
            @lupsyn said in Select and Start not Work: "starting movie record...":
            Most likely your Select key is bound to O , that's the default key-bind for recording (see https://docs.libretro.com/guides/input-and-controls/#hotkey-controls). If your Picade's control emulates a keyboard, you can either disable that binding in the configuration file, or re-configure the Picade's controller/keyboard to use another key.
            • L
              lupsyn @mitu
              @mitu due https://github.com/pimoroni/Picade-Sketch/blob/master/Picade/Picade.ino i think it's pretty time consuming reconfigure the hardware due the picade-hat is recognized as a keyboard. I just changed forcing the value : input_movie_record_toggle into /opt/retropie/configs/all/retroarch.cfg to be not 'o'.
