    Using an shared drive on PC for roms.
    network share
    12 Posts 2 Posters 1.7k Views
      raulitob
      Thanks for the reply.
      So quick question then, I have to make sure the retropie sees the network shared drive correct?
      IN this case it's the drive labeled "d" so i did a
      smbstatus --shares
      So when i run pi@retropie:/mnt $ sudo ls -l /var/lib/samba/usershares
      total 0
      It shows no shares.
        mitu Global Moderator @raulitob
        @raulitob No, that's not the way to do it. smbstatus shows the shares exported by the PI, not the ones that might be on the network.
        If you want to see the shares exported by your Windows machine, just open Windows explorer and put \\localhost in the location bar, this should list the shares on your Windows machine.
          raulitob
          @mitu said in Using an shared drive on PC for roms.:
          \localhost
          Ok I did that and see my D drive as being shared and the network path is
          \Office\d
          So now let me start from scratch to mount this
          First I want to copy over the file structure so I run
          cp /etc/emulationstation/es_systems.cfg /home/pi/.emulationstation/es_systems.cfg
          So does this line /home/pi/.emulationstation/es_systems.cfg have to be the path to the shared drive or?
            @raulitob You don't need to copy the ES's configuration file over.
            If you intend to keep your ROMs only on the network share, then first make sure the file share mounts ok and it's writeable from the PI system, afterwards you can just follow the docs to transfer your ROM to the share and mount it on boot.
              I think it would be easier if you'd create a sub-folder on your drive (D) and share it with the retropie name on the network. Then in your script just mount \\office\retropie over the /home/pi/Retropie/roms folder. Copy the ROMs folder first from your RetroPie file share so you'd have D:\retropie\psx, D:\retropie\amiga, etc.
                raulitob @mitu
                Ok great so what i did is make a folder in that D drive so
                D:\RETROPIE\roms
                and then changed the sharing permissions on windows to "everyone" and made it read/write by everyone.
                Now do I have to delete the rom folder in the retropie or leave it as is?
                then copied the rom folders over from the retropie
                This is my autostart.sh
                the RETROPIE folder on my shared drive is set to allow a guest user with no need for a username/password
                Note: so on my shared drive on my windows 8 pc it has the following path to Retropie
                D:/RETROPIE/roms/
                Do i have to put the ip address in there as well?
                I realized my D drive has a name , would that make a difference?
                Thanks!
                  @raulitob Before editing the file, try running the command from the SSH session and see if it works. The \\office\retropie share should be mounted over the /home/pi/RetroPie/roms. You should
                  • copy your ROM folders from \\retropie\roms to D:\retropie\roms
                  • try running the mount command from the putty session
                  mount -t cifs -o guest,uid=pi \\office\retropie /home/pi/RetroPie/roms
                  and then see if your \\retropie\roms share contains the files from your disk.
                  The name (label) of yor disc in Windows doesn't matter. You don't have to use the IP address, unless your RetroPie system doesn't know the office address.
                    raulitob
                    mount -t cifs -o guest,uid=pi \office\retropie /home/pi/RetroPie/roms
                    Thanks again for the suggestion. So i tried that and got this result
                    pi@retropie:~/RetroPie $ sudo mount -t cifs -o guest,uid=pi \\office\RetroPie /home/pi/RetroPie/roms
                    mount.cifs: bad UNC (\officeRetroPie)
                    So then I reversed the slashes and got this
                    pi@retropie:~/RetroPie $ sudo mount -t cifs -o guest,uid=pi //office/RetroPie /home/pi/RetroPie/roms
                    mount error(13): Permission denied
                    does that mean the folder on my pc has not been shared right or?
                    Thanks!
                      raulitob
                      Oh Wait I think i got it
                      pi@retropie:~/RetroPie $ sudo mount -t cifs -o username=username,password=pass //192.xxx.x.xxx/RetroPie/roms /home/pi/RetroPie/roms
                      Didnt get any errors when I ran that.
                        raulitob
                        I verified its loading roms from my shared drive, thanks so much for the help!
