    [Solved] How to bind a shell command to a hotkey? (raspi2png)
    hotkeyshortcutscreenshotraspi2png
    59 Posts 6 Posters 14.6k Views
      @roslof 's solution is also better when you just want to change something to the script command, since you don't need to re-start the thd service or edit the .conf file - any edits to the .sh file will take effect immediately.
      • roslofR
        roslof @Clyde
        @Clyde Thanks man. Still new here.
          Clyde @mitu
          @mitu The script version even relays the output of the script commands to triggerhappy's status output. I wasn't sure if it would do that. But I will keep it as optional for my solution post, because it adds more complexity, and one command should be enough for most people.
          @roslof You're welcome! Besides, in some cases can deletion be advisable, like in this thread from me where @meleu's solution made my own completely obsolete (and wrong for many reasons). But I still added a remark about it original content. 😇
            Clyde
            @roslof One question about your script variant: Is there a reason that you're using nohup and 0<&- &>/dev/null &? I'm asking out of curiosity and simplicity, because it seems to work as well if I just invoke the script by path and name, as do some triggerhappy guides I found online.
            And since I linked to your solution in mine, could you please add a remark that the script has to be made executable? (In my example for the owner "pi", or for "others" if the owner is root, since my solution configures triggerhappy to run as that user.)
            roslofR 1 Reply Last reply Reply Quote 0
            • roslofR
              roslof @Clyde
              @Clyde As requested, I added a note in my previous post about setting the executable permission.
              Also, you're absolutely right about my use of nohup. It's not necessary for such a simple/quick script. nohup ensures the process doesn't stop until it's done. Overkill for the near-instant execution of the script. Again, my newbie-ness is shining through.
              Regardless -- Cool write-up on nohup, its uses, and why output needs to be considered for other, longer tasks:
              https://www.maketecheasier.com/nohup-and-uses/
              I revised my post with the simple path/script and included an edit note with my original nohup line for reference...
              Cheers
              ClydeC 1 Reply Last reply Reply Quote 1
                Clyde @roslof
                @roslof Perfect, thanks!
                  cyperghost @Lolonois
                  @Lolonois said in [Solved] How to bind a shell command to a hotkey? (raspi2png):
                  @hermit triggerhappy is not related to retropie. AFAIK %ROM% or $ROM is not available from the environment. However, to get the rom file name you may start with
                  basename `ps a | grep RetroPie/roms | head -1 | awk '{ print $NF }'`
                  Without a physical keyboard attached the tool jslisten may be an option.
                  This is definitly the master path for such purpose. Why it gets so less attention?
                  Together with the jslisten tool we can call any script and manipulate filenames (because we aren't restricted to one liners) ;)
                  Thx @Lolonois for this nice suggestion ;)
                  @mitu @Clyde
                  The triggerhappy solution is also nice but imho the joypad usecase is a real fine way to coop with.
                  Btw: You can always use GPIO inputs to call commands
                    Clyde @cyperghost
                    @cyperghost said in [Solved] How to bind a shell command to a hotkey? (raspi2png):
                    If you're not like me and prefer USB connections. ;) (because, I don't know, lazyness?)
                      cyperghost @Clyde
                      @Clyde Well ... I think it's not lazyness. I think with this Breadboard unit on Amazon.de there is no space for any excuse ;)
                      So you develop your scripts and connections on this board and just take them over to your RetroPie ;)
                        Clyde @cyperghost
                        @cyperghost If I compare this to a ready-to-use usb device like a keyboard or game controller, I think I can still plead lazyness with a clear concience. ;)
                          cyperghost @Clyde
                          @Clyde Now we are getting closer why I entered this thread ;)
                          So does triggerhappy work out of the box with joypads? If yes then this would be a real cool deal ;)
                          Maybe I will post a thread of annother solution that's only script based ;) Stay tuned ;)
                            mitu Global Moderator @cyperghost
                            If it's reading the events correctly from /dev/input/eventX, I see why not. You can verify like @clyde did via thd --dump /dev/input/*. Looking at the supported event types (thd --listevents), I think it should work.
                              cyperghost @mitu
                              @mitu Yes I'm reading the github content now. Sounds feasible for me to get this work with js0 as input source. Even one issue on github explainded that there were inputs of buttons detectable.
                              But I'm also in annother doc for retropie: Take and Scrape Your Own Screenshots. There it is explained
                              1. How to setup the screenshot function with button
                              2. How to retrieve Screenshot name from ROM name
                              3. How to store them per system
                              The only minus point of the raspi2png internal retroarch solution is... this will work (of course) only in lr- core emulatores ;) Or did I misunderstood the whole thread?
                              • H
                                hermit
                                Rapi2png , I think it works with any emulator.
                                I used it with uae4arm which is not Libretro
                                  @cyperghost It works with any emulator, since it screenshots the framebuffer. What you should - actually - do is make it work on the 'Droid (i.e. find a raspi2png substitute).
                                    cyperghost @mitu
                                    @mitu said in [Solved] How to bind a shell command to a hotkey? (raspi2png):
                                    Yes... I ment that the retroarch internal solution will only work on lr-cores
                                    @hermit @mitu
                                    Corrected previous posting
                                    But I think the internal screenshot modul of retroarch should not be underestimated, too ;)
                                      @cyperghost Well, if you're using RA, it gets much easier - like in the wiki page you posted. It's enough to bind a button (for instance B, which is mapped to Reset Content) to take a screenshot via the hotkey.
                                        cyperghost @mitu
                                        @mitu so the thread should contain all application purposes.
                                        about the odroid.
                                        1. I'm not a chip developer
                                        2. the device and it's esp. the graphic drivers are barly maintained
                                        3. I'm the (proud??) owner of such a device but I prefer the Pie
                                        Maybe the device will get better support if more devs will take buisness on development ... but the XU4 is far away from being called a "newcomer" it's in meantime a 4 year old boy ;)
                                        But let us talk in other threads about this SBC ;)
                                          What I meant - since you have one - maybe you can find an equivalent program to raspi2png for the Droid and be able to test it (not create one from scratch). Something like fbgrab or fbdump maybe.
                                          • roslofR roslof referenced this topic on
