    There is no audio for HDMI, Help!
    audio outputhdmi audio
    3 Posts 2 Posters 358 Views
      alicesim1
      I have a problem, after an update of RetroPie, I stop working the audio for HDMI, it does not work.
      In contrast audio output by 3.5mm stereo jack if it works.
      How can I solve the problem of HDMI audio output?
        mitu Global Moderator @alicesim1
        @alicesim1 can you give more details about your system - https://retropie.org.uk/forum/topic/3/read-this-first.
        Where exactly are you noticing the audio doesn't work - game/emulationstation ? Did you check the Audio menu in the RetroPie and set it to HDMI ?
          alicesim1
          Thanks for answering, check that other users had the same problem, so check my settings thoroughly:
          thanks to this help guide:
          https://retropie.org.uk/docs/Sound-Issues/
          This step solved the problem for me:
          USING THE BUILT-IN HDMI AUDIO
          If you have a standard RPi and want to send audio over the HDMI connector then it should just work. In some instances though, you will need to manually modify the raspberry pi boot config file (sudo nano/boot/config.txt) and ADD the following lines to those already there:
          # forces HDMI mode
          hdmi_drive=2
          # Setting hdmi_force_hotplug to 1 pretends that the HDMI hotplug signal is asserted, so it appears that a HDMI display is attached. In other words, HDMI output mode will be used, even if no HDMI monitor is detected.
          hdmi_force_hotplug=1
          # Pretends all audio formats are supported by display, allowing passthrough of DTS/AC even when not reported as supported.
          # May not be needed for all HDMI devices
          hdmi_force_edid_audio=1
          Once you've made the change, save the file, restart your Raspberry Pi, and move onto Step 2.
